big block vs. small block? - Ford Truck Enthusiasts Forums
Old 02-18-2003, 01:37 AM
lilpig88 lilpig88 is offline
lilpig88 is starting off with a positive reputation.
i know this has probably been answered before, but i searched and couldn't find anything. this is probably a really easy question too, but all the people i've ever talked to can't give me a very good answer. what is the difference between a big block and a small block? is there a distinct line where it switches? or is it just the "heavy dutiness" of an engine (wall thickness etc.)? i would love to find a good answer to this question.
thanks
Old 02-18-2003, 01:45 AM
F100DREAM's Avatar
F100DREAM F100DREAM is offline
F100DREAM is starting off with a positive reputation.
I submit this to you for information.
Short Block: An engine WITHOUT the head(s). Usually includes the crankshaft, camshaft, and pistons.
Long Block: An engine WITH the head(s). Usually does not include the oil pan, valve covers, and manifolds.
Small Block: The smaller of a manufacturers two series of engines.
Big Block: The larger of a manufacturers two series of engines.
There is an overlap of small and big block displacements. Note also that a small block can be a long block. The terms define different characteristics of the engine. Doc.
Old 02-18-2003, 01:50 AM
Ratsmoker's Avatar
Ratsmoker Ratsmoker is offline
Ratsmoker is starting off with a positive reputation.
Big Block and small block are more of a chevy and dodge thing than a ford. We do refer to the 385 series and FE series as big blocks. The 220 - 351W blocks are considered small blocks. The 335 series is highly debated. Cubic inches or wall thickness has very little to do with it. Ford makes improved 351W blocks that will take a larger bore than my 390. Ford made many different V8 blocks and chevy only made 2 different styles. If you are racing your ford in a small block only event you will probably need a windsor series engine. The cleveland might also be accepted.
Old 02-18-2003, 02:32 AM
F100DREAM's Avatar
Thank you Ratsmoker, I meant to mention that term being a "non-ford" term, Much like posi-trac.
Old 02-18-2003, 03:10 AM
Ratsmoker's Avatar
We posted at the same time. I had no idea you had answered
Old 02-18-2003, 11:48 AM
thanks for the info. so there really is not a distinct big and small block, just a way that certain people refer to different blocks.
thanks
Old 02-18-2003, 11:35 PM
canzus canzus is offline
canzus is starting off with a positive reputation.
Quote:
thanks
Heres some mud in the water, so to speak...
The small block has a bore spacing of 4.380",
The 335 series is a small block, Bore spacing 4.380",
The FE is neither a big block, or small block, same
goes for the Y-Block...
The 385 series is a big block, bore spacing of 4.90"
But, the 351M/400, has a deck height nearly 385 series
tall, (10.302" vs 10.322") but the small block bore spacing.
Are we confused yet??
Old 02-18-2003, 11:51 PM
Ratsmoker's Avatar
The FE was a big block long before the 429/460 was around. Plain old fact.
Old 02-19-2003, 04:01 AM
TorqueKing's Avatar
TorqueKing TorqueKing is offline
TorqueKing is gaining momentum as a positive member of FTE.
so what's the deal with the 351W block that you said can take a bigger bore than a 390? how do you get one of those, and how much bore can they take?
Old 02-19-2003, 04:43 AM
Ratsmoker's Avatar
Dart makes a block that they claim will take a 4.185" bore. It comes with a standard 4.125" bore. Not a whole lotta 390's out there that will safely run this wide but a very very few of them will.
Old 02-19-2003, 10:08 AM
TorqueKing's Avatar
I've read about that block, I was hoping you were talking about some long lost factory block. The experts at Car Craft said that the Dart block could probably go to 4.200" without any problems, but I think I'd be happy with whatever they'd recommend if I was gonna pay $2,000 for an engine block.
Old 02-19-2003, 06:25 PM
Ratsmoker's Avatar
I don't know of any siamesed factory 351W blocks but I am no windsor history buff. I think ford makes some motorsport blocks that will go pretty far also.
Old 03-06-2003, 01:26 AM
79Lariat 79Lariat is offline
79Lariat is starting off with a positive reputation.
How about we simplify this. If a 289 head will bolt on, it's a small block. If a 428 or 429 head will bolt on it's a big block. We can't go by bellhousing size or the chebbies would all be the same.
Old 03-12-2003, 11:45 AM
big1 big1 is offline
big1 is starting off with a positive reputation.
The standard 351W can be stroked to 427 cu.in., by using a highly modified 400M crank and 360 Mopar rod's. This can be bought from PAW racing.
Old 03-12-2003, 05:29 PM
Lectrocuted Lectrocuted is online now
Lectrocuted is starting off with a positive reputation.
FRPP Sportsmans 351 block 2 bolt main $1200. Siamesed 4 bolt main $1700-$1800. Prices may be wrong. Look up Ford Motorsports 351 block on Google and you'll find some info.
360 spark plugs in a 302? mddibenedetto FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 01-28-2011 06:47 PM
MustangII; power or not fergusonicford 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 11-14-2006 07:20 AM
Big block or small block 77fordguy General Automotive Discussion 17 08-04-2005 12:04 AM
Aerostar Block Drain ? Ed Aerostar 9 06-13-2005 09:35 PM
Small/Big Block? Saurian Performance & General Engine Building 9 03-30-2004 09:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
