Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 08-31-2010, 08:30 PM
climber338 climber338 is offline
Garage is empty, add now
climber338 is starting off with a positive reputation.
are there any bad effects from using bio diesel??
Hey guys ive been doing a little research and im very interested in using bio diesel. Im planning on using it in an IDI or a first generation powerstroke. I was planning on purchasing one of the processors from northern tool. Are there any bad effects on the engine if i were to run them on strait bio diesel? Ive heard of people running them on 50/50 but i would rather keep it simple and be able to use it strait in the truck. Ive also heard about special fuel hoses that i should use if i were to use bio diesel and if there are any kits? Any comments would be awesome.
  #2 (permalink)
Old 08-31-2010, 08:47 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
There are 0 ill effects from using WELL MADE biodiesel. As long as you make a quality product you will have no problems. I've been making and using bio for over 6 years without any problems. You will need to mix with dinodiesel in the winter months if you live in a cold climate. All Ford diesels after 1994 have bio compatable fuel lines already, so unless you buy a pre-94 your good to go!
If you need any help just post up in this forum. We have lot's of people that are willing to help.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 08-31-2010, 08:51 PM
that is what i wanted to hear.
  #4 (permalink)
Old 09-01-2010, 12:02 PM
TurnerBioDiesel's Avatar
TurnerBioDiesel TurnerBioDiesel is offline
2003 Ford Excursion
TurnerBioDiesel is starting off with a positive reputation.
As Fabmandelux said. If you run fuel with a high soap content you will be plugging filters as will water in your fuel. I was told on another forum a good thing to do is use a 2 micron filter and water trap filter on your finished product before it enters your tank. I would also suggest getting soap test kit and a water test kit. Depending on where you are at 50-50 in winter is ok.
  #5 (permalink)
Old 09-01-2010, 12:10 PM
2003 Ford Excursion
Also forgot to say BioDiesel will reduce your emissions and should give better lubricity over Petro Diesel. (should make your motor run longer with in spec fuel) You will notice a 10% decrease in fuel milage and power. I notice it in my 6.0
  #6 (permalink)
Old 09-02-2010, 07:10 AM
JacksSmith JacksSmith is offline
JacksSmith is starting off with a positive reputation.
I don't think their would be any bad effect on engine. Because its a cleanest form of fuel means it fully burns living no percent of carbon behind. I am not expert on automotive but i think it will not harm your engine but the engines are made to run on oil and using bio-diesel that is a factor that need to be addressed.
  #7 (permalink)
Old 09-03-2010, 09:01 PM
amadas350's Avatar
amadas350 amadas350 is offline
2004 Ford F-350
amadas350 is starting off with a positive reputation.
only down side to using biofuel in older vehicle is that it really cleans out our fuel system and can cause you to change your fuel filters more than you normally would during initial use. everything on our farm needed fuel filters changed regularly when we started using it.
  #8 (permalink)
Old 09-05-2010, 01:55 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
One of the bad effects is the exhaust smell makes people hungry...
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #9 (permalink)
Old 09-05-2010, 05:14 PM
MZ5 MZ5 is offline
MZ5 is starting off with a positive reputation.
As has been noted, it is critical to make good fuel. LOTS of people don't, and so they have trouble; that's not surprising. Well- and properly-made biodiesel will lower wear in your engine, and also lower emissions somewhat. MPG will also drop; the research (EPA-spec testing in properly controlled circumstances) shows ~3% drop for B20. I don't recall numbers for B100. Be aware that biodiesel is much more highly solvent than petro-diesel, so you may need to change your fuel filter(s) shortly after you begin using it. I'd suggest looking to the University of Idaho and/or the University of Missouri for technical articles and reference material.
What I'm saying above is for well-made biodiesel from rapeseed and/or soybean starting material. I know that it's popular to make diesel fuel out of WVO, but I'm not familiar with scientific research into its properties and effects. If cleaned, trans-esterified, and processed properly, I wouldn't expect the results to be too terribly different.
  #10 (permalink)
Old 09-06-2010, 04:48 PM
djjoshuad djjoshuad is offline
djjoshuad is gaining momentum as a positive member of FTE.
I just (Saturday) bought a 2011 6.7L F250. I haven't even cracked the 400 mile mark... if I started making and using biodiesel soon, would I need to change my fuel filters within 500 miles? I see this recommendation everywhere but it seems like a new fuel system might not need the filters changed. Thoughts?
Also, there is a lot of marketing touting the engine's ability to run B20 from the factory. Is this just marketing, or is there something new that makes this possible? Also, does B99 or B100 need any sort of modification? If not... why wouldn't they just say that it can run B100? Seems like better marketing to me.
Keep in mind that I'm new to diesel, especially biodiesel. I'm just looking for feedback and maybe some guidance . Thanks in advance!
__________________
2011 F250 6.7L CC FX4 King Ranch
2010 Wildcat 31BH2B 35' Fifth Wheel RV
  #11 (permalink)
Old 09-06-2010, 06:08 PM
binuya's Avatar
binuya binuya is offline
binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.
To your first question, no. The filter change recommendation has more to do with older vehicles with fuel system build up which would get loosened up from biodiesels strong solvent action. This build up would then create potential clogs in the filter. I think even my 2001 PSD is too 'new' to have
problem causing build up since it never happened to me when I started using biodiesel 3 years ago. Now I run my own B100 most of the time, and B50-B70 during the colder months, and no issues.
My thinking on the factory B20 recommendation is that it's a liability issue. Even if the biodiesel were not up to spec, at 20% it would be diluted down enough with petro diesel that it would pass through without harm. It seems to me that if there were a problem with your new 6.7, and it was confirmed that bio at a greater percentage than B20 was used, it would be easier to blame the issue on the fuel. Maybe it's too much of a grey area, being that there are quite a few homebrewers like myself out there. Fuel quality can vary widely. I don't know, these are just my own speculations I'm throwing out there, and hopefully someone who knows for certain will chime in.
__________________
2001 F250 7.3 CC SB 4x4 Lariat
S&B Intake, MBRP 4" Turbo Back, HPX, AIH Delete, Hutch and Harpoon,
Isspro EV2's, Bilsteins, Warn Premium Hubs, Firestone Bags with Airlift onboard, Fumoto,
Homebrew American Biodiesel (B100 whenever I can)
1995 Mercedes Benz E300D, 2004 Mercedes ML350
  #12 (permalink)
Old 09-06-2010, 06:10 PM
binuya's Avatar
Oh, and by the way, congrats on your new rig!
__________________
  #13 (permalink)
Old 09-06-2010, 06:36 PM
1935 Ford pickup
Sorry, biodiesel in higher concentrations than B-20 will not work in your 2011 Ford. Because of the PDF system in the new Fords and the way they work ( by injecting raw fuel into the cylinder during the exhaust stroke) the excess bio will run down the cylinder and contaminate your crankcase oil.
More here: Biodiesel Compatibility - Engine Biodiesel Fuel Compatibility - Popular Mechanics
__________________
  #14 (permalink)
Old 09-06-2010, 10:05 PM
MZ5 MZ5 is offline
If you actually read that article, fabmandelux, you'll see that they exclude the engines that use DEF from the problem of fuel dilution. Since the '11 Ford uses DEF, the issue raised by that article is not applicable ...according to the article.
  #15 (permalink)
Old 09-06-2010, 10:51 PM
so, if I read that article correctly, I could run whatever concentration of biodiesel I like (and can find/produce) since my truck uses DEF instead of injecting extra fuel during the exhaust stroke. This is good news!
Also, thx for the 'grats, binuya. This rig has turned more heads in 2 days than any other vehicle I've owned. I'm getting compliments from random strangers . Now, if it can generate the same kind of attention that my old '97 cobra did about 10 years ago... of course I'm married now and I suppose my wife might not appreciate being flashed by college girls on the highway
__________________
Tags
67, bad, bio, biodiesel, biofuel, diesel, effect, effects, excursion, ford, fords, human, running, truck, whos
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
