Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 08-31-2010, 06:17 PM
becca33308 becca33308 is offline
Garage is empty, add now
becca33308 is starting off with a positive reputation.
Red face 1961 Ford F100 unibody vin decoder
Hi I have a 1961 Ford Unibody pick up and I want to know the factory specs for restoration-
Vin #F10CN240209
MANY THANKS, IM LOST!!
  #2 (permalink)
Old 08-31-2010, 06:56 PM
garbz2's Avatar
garbz2 garbz2 is offline
1963 Ford F-100
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
F10CN240209
F10= 5000# GVW nominal 1/2 ton
C= 292 MD V8 2 Barrel carb
N= Norfolk Virginia (where the truck was assembled)
240209= Born in December 1961. The truck is a 1962 based on this.
Post the remainder of the info on the glove box door's serial number tag. We can decipher the remainder of the things like trim, trans and axle.
Garbz
__________________
98 528I BMW
64 F100 "Christine II" 390 NP435 6" lifted 2 wheel drive
63 F100 Uni Custom under construction 4" off the pavement and built to drive.
69 M250 Crew Hiboy 472 C6 Ranger, getting a full rebuild.
  #3 (permalink)
Old 09-01-2010, 06:49 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by garbz2 View Post
F10CN240209
The SERIES code of F10 decodes to F100 2WD only.
The VIN's SERIES code has nothing to do with what the GVW is, the MODEL code is the determining factor.
1961/66:
If the MODEL code is F100 or F102 (PA only) = F100 2WD, 5,000 lbs. GVW.
If the MODEL code is F101 = F100 2WD, 4,200 lbs. GVW.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #4 (permalink)
Old 09-01-2010, 04:12 PM
garbz2's Avatar
1963 Ford F-100
1961/66:
Bill,
With the lack of additional info all F10 are F100 GVW. Hence the asking for additional information.
Sheesh....
Garbz
__________________
98 528I BMW
Tags
100, 1961, 1963, code, decoder, f100, ford, gvw, identifying, number, numbers, truck, trucks, unibody, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
