engine mounts
It depends on which V8. There are two basic types. One is a crossmember which goes under the engine and mounts to the inside of the frame and has tabs to bolt the engine to. This is usually a bolt on set up. The other is triangular shaped mount which welds to an inside boxed frame on the "feet" of the triangle, and the "point" has an engine specific fitting to match a Ford ( We hope ) or Chevy. I'm sure someone will post a pic before I can. Hope this helps.
I have a 289 in my 52 F1 and I am very happy with it. I'll take some pics of my mounts and try to post them. They are the same as a 302. If you're going bolt on, there are many sources for the crossmemeber type. If you need a supplier let me know, I'll post the web sites. I bought a 1968 Fairlane and pulled the 289/C4 and a 9" rear all for $300. Having all the parts already matched saves lots of problems trying figure how Ford made what in some production runs than others.
Thanks for the kind words about my truck. I'm about a 1 1/2 hours from you up 95, just outside DC. You're on the right track, keep it simple. It gets hard enough anyway!!! There should be plenty of old donor cars around you. Head for the mountains. I found the truck and donor in West Virginia. Good Luck. Lots of good people on this site eager to help.
Another good place to find them and pics is in the parts catalogues for various companies.
Here's a link to them in JEGS:
motor+mounts - JEGS High Performance.
The mounts you need are in this batch somewhere - I put a 289 in my 55 some years ago and got them at JC Witney - worked great:
Your Search Results - JCWhitney
And a few local links on the subject. You might use the Advanced Search here to find previous discussions. Here's two of the hundreds that are listed.
https://www.ford-trucks.com/forums/9...-302-help.html
https://www.ford-trucks.com/forums/8...ord-truck.html
Yeah, a shortage of items, availability, and install tips here isn't going to be a problem. Probably deciding which ones will burn more brain cells!
Hint: be thinking about both your front end plans (staying stock or going IFS) AND exhaust routing space on the drivers side between the motor mounts and steering box (if you plan to stay stock there as well) - Sandersons
Here are a few more places to look: www.classicperform.com www.dennis-carpenter.com www.vintageford.com . BlueOval is right, a tubular crossmember mount is what you want if you're staying with the original front suspension
