wont rev over 1500rpm Help!!
Following this thread
Action - can you elaborate on the oil bypass valve a bit? What would be the symptoms of a problem with this valve, and what's the fix? I have a power-loss proble tha I think I've pinpointed as a trans problem, but I'm always on the lookout for other causes.
I assume a problem with the low pressure oil system would lead to starving the HPOP of oil but I'd guess the truck would just stall/not start in this case - and the HPOP reservior would be found empty.
Is there something more to a bad bypass valve than this?
football4life
12-29-2016 05:18 PM
MasterKrause
17
07-06-2015 05:26 PM
4Snow
6.4L Power Stroke Diesel
13
02-24-2013 07:57 AM
