A Word of warning about the PCV valves. - Ford Truck Enthusiasts Forums
Old 08-30-2010, 08:47 PM
housedad's Avatar
housedad housedad is offline
housedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputation
I posted about this in the V10 forum, but I wanted to let everyone here know to check their PCV valve.
I had my mileage dropping real bad earlier this year. I changed the plugs, and they had some deposits. Not bad, but some. My mileage and power came straight back.
Over the next few months, the mileage again sent slowly bad. I was to the point of 8 MPG higway at 65 mph.
I decided to do the plugs again, and they were heavily encrusted with ash deposits. I suspected light amounts of oil, and checked the PCV valve. It had gone the way of the wind.
No codes showed. My PCV is the type with a wire and electrical sensor on it.
After the new plugs and the PCV, It runs better than it ever has. No more very slight roughness. Lots more power, and the mileage is right back.
Check your PCV and plugs if your mileage is dropping!!!
Bion
Old 08-30-2010, 08:52 PM
william_04_x's Avatar
william_04_x william_04_x is offline
william_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputation
Nice find, Bion. I bet that will help a lot of people.
Old 08-30-2010, 10:04 PM
TYZ78F150 TYZ78F150 is offline
TYZ78F150 is gaining momentum as a positive member of FTE.
I went to autozone one day to get oil and filter for my 5.4, and had the kid look up one for it and he said they don't have one? I haven't tried again, but will now. Thanks
Old 08-30-2010, 10:13 PM
housedad's Avatar
BTW, for the 2004 and 2005 owners, The PCV Valve is the blue plastic tube affair sticking out of the middle of the passenger side valve cover.
To get the hose off, You need to reach around it and there is a yellow tab sticking out. catch it with your fingernail and pull it away sideways about 1/4 inch from the connector. Do this while you are pulling them apart lightly.
To get the PCV valve out, it is sort of camlocked into the valve cover. Grab it firmly and twist counter clockwise about half a turn. It will come right out.
I wanted to post this since it is so different from the 2000-2003 models, and it took a bit for me to figure out without buggering up the connector or anything else.
You can get them from Rockauto or your dealer. Napa, Autozone, Advanced, and Pep Boys all said the same thing. No reference for it. Even when I gave them the ford part number off the side.
Here is a pick of the valve:
Old 08-30-2010, 10:41 PM
Shepherd2 Shepherd2 is offline
Shepherd2 has a good reputation on FTE.Shepherd2 has a good reputation on FTE.Shepherd2 has a good reputation on FTE.
That's just crazy.I worked at a dealership for over 10 years and never even knew those things existed. If they can find a way to make something so simple so complicated ...
Old 08-31-2010, 12:49 AM
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
Someone "rep" Bion for me please. I gotta spread it around...
Old 08-31-2010, 03:17 AM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
Quote:
Done.
Old 08-31-2010, 11:50 AM
Thanks alot housedad. I changed all my plugs about 2k ago. I think I'll go ahead and change the pcv, it does act like it has a very slight miss, especially on start up.
Old 08-31-2010, 01:11 PM
perryg114 perryg114 is offline
perryg114 is gaining momentum as a positive member of FTE.
So what is the wire for?
Perry
Old 08-31-2010, 02:39 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
Done!
This should be a sticky in the V10 forum, I'll raise it to Art...
Old 08-31-2010, 03:02 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
That's bizarre, I never knew they made a PCV valve like that.
Old 08-31-2010, 04:52 PM
housedad's Avatar
Wow. Thanks for the rep points, guys.
I'm just glad to share to prevent someone else from having the problems.
Old 08-31-2010, 05:49 PM
Mr_Fast_Bucks Mr_Fast_Bucks is offline
Mr_Fast_Bucks is gaining momentum as a positive member of FTE.
Went to the ford dealer today to buy a PCV. (2003 V10). Apparently they used two types, heated VS non heated. Mine has the heated type (there are small coolant lines going to it) and they had to order it.
Old 08-31-2010, 06:10 PM
Cardiac69's Avatar
Cardiac69 Cardiac69 is offline
Cardiac69 has a good reputation on FTE.Cardiac69 has a good reputation on FTE.Cardiac69 has a good reputation on FTE.
Where is the one for the 2000 V-10? Is it also in the valve cover?
Bob
Old 08-31-2010, 06:49 PM
cbradford cbradford is offline
cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.
Bion
Just wondering if you noticed a difference in oil consumption?
02/PCV-Bad Mileage-strange g3ride69 Explorer, Sport Trac, Mountaineer & Aviator 2 03-24-2016 05:56 PM
sluggish acceleration in 4.6 Aviator 78_79ford Explorer, Sport Trac, Mountaineer & Aviator 29 08-28-2015 05:24 PM
PCV/Breather. cstephens Ford Inline Six, 200, 250, 4.9L / 300 15 11-08-2014 10:27 PM
Oil in the air box & PCV replacment on 08 5.4 08F1Tizzy 2004 - 2008 F150 1 11-15-2012 08:41 AM
02 Escape PCV, cranckcase vent oil seperator Oil leak Battman76 Escape & Escape Hybrid 3 02-02-2012 07:50 AM
Tags
10, 2000, 2001, 2005, 2v, 54l, 68, control, excursion, ford, inline, location, pcv, picture, sway, v10, v3, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
