A Word of warning about the PCV valves. - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 05-01-2011, 01:14 AM
wpnaes's Avatar
wpnaes wpnaes is online now
FTE SoCal Chapter LDR
wpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputation
OK, got tired of not fully understanding this birds nest of of a PCV, so I dug into it today (was doing the heater valve replacement and was in the neighborhood, so why not?).
Now i understand the 'heated' valve. Heated with coolant. It yanked right out, pulled the 3 hoses (on a 2000 V10) and sprayed her out with some carb cleaner. Works like a charm (worked ok before cleaning too).
Some pic's below. No, mpg benefit expected.
  #47
Old 05-01-2011, 01:17 AM
wpnaes's Avatar
A few more pics...
First pic is removal of a vacuum hose that get's in the way.
Don't forget to reconnect.
  #48
Old 05-01-2011, 01:20 AM
wpnaes's Avatar
Ok, just a few more pics...
Really does this need to be heated with coolant???
Does it freeze up on a cold morning? and all hell breaks loose?
  #49
Old 05-01-2011, 06:57 AM
Cardiac69's Avatar
Cardiac69 Cardiac69 is offline
Cardiac69 has a good reputation on FTE.Cardiac69 has a good reputation on FTE.Cardiac69 has a good reputation on FTE.
Awesome! Thanks for taking the effort to do this. Rep points to you!!
  #50
Old 05-01-2011, 11:04 AM
wpnaes's Avatar
Quote:
Originally Posted by Cardiac69 View Post
Anyone have an extra black plastic fitting from the drivers side valve cover? It has a breather attached to it that goes to the air intake right before the throttle body. It looks like a PCV valve but is hollow.
Mine has a crack in it and Ford does not sell it.
YOU HAVE TO BUY A NEW VALVE COVER!!!!
That is unreal......
Thanks,
Bob
Bob, didja ever find one?
  #51
Old 05-01-2011, 12:48 PM
Cardiac69's Avatar
Quote:
No, I gorilla glued it back together and it has been fine.
Thanks for asking!!
  #52
Old 07-03-2011, 12:13 PM
Ridenred333 Ridenred333 is offline
Ridenred333 is starting off with a positive reputation.
so what is the plastic thing sticking out of the other valve cover on the left side. mine broke when i pulled on the hose.
Quote:
Originally Posted by housedad View Post
BTW, for the 2004 and 2005 owners, The PCV Valve is the blue plastic tube affair sticking out of the middle of the passenger side valve cover.
To get the hose off, You need to reach around it and there is a yellow tab sticking out. catch it with your fingernail and pull it away sideways about 1/4 inch from the connector. Do this while you are pulling them apart lightly.
To get the PCV valve out, it is sort of camlocked into the valve cover. Grab it firmly and twist counter clockwise about half a turn. It will come right out.
I wanted to post this since it is so different from the 2000-2003 models, and it took a bit for me to figure out without buggering up the connector or anything else.
You can get them from Rockauto or your dealer. Napa, Autozone, Advanced, and Pep Boys all said the same thing. No reference for it. Even when I gave them the ford part number off the side.
Here is a pick of the valve:
  #53
Old 07-03-2011, 01:51 PM
superjocko superjocko is offline
superjocko is starting off with a positive reputation.
^ The fitting on the opposite valve cover attaches to the hose that allows fresh air into the crankcase. The circulation of air throughout the crankcase, or "ventilation", wouldn't be possible unless air was admitted somewhere. In addition, under conditions of low engine vacuum (large throttle openings) the blow-by gases that are not being cleared from the engine by the PCV valve are free to enter the intake tract through that fitting and hose on the opposite valve cover. They can then be pulled through the throttle body with the rushing intake air and into the intake manifold, ultimately to be burned in the engine. Regardless of whether we have vacuum or not, the blow-by gases will be burned in the combustion chambers, rather than released to the atmosphere.
  #54
Old 07-03-2011, 05:11 PM
jasonodsky's Avatar
jasonodsky jasonodsky is offline
jasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to behold
housedad's instructions for removal were spot on and the job took only minutes start to finish. Currently Oreiley Auto Parts has the Motorcraft electrically heated PVC for $23.
My oil consumption was pretty significant and when I removed the old PCV, I could still shake it and hear the ball move around but it definately sounded encumbered and not clean like the new one.
I will report back afer a few thousand miles to see if consumption has reduced with just the change.
  #55
Old 07-03-2011, 08:15 PM
loleuiha's Avatar
loleuiha loleuiha is offline
loleuiha is starting off with a positive reputation.
Where is the one for the 2000 V-10? Is it also in the valve cover?
Bob
Yes Bob Pass side Valve cover right in the middle.
Laki
  #56
Old 07-14-2011, 11:02 AM
LivingLarge's Avatar
LivingLarge LivingLarge is online now
LivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputation
I usually burn about a quart and a half of oil on my round trips to TN. from FL. (round trip and local cruising about 2500 miles). Highway speeds 70-80mph.
I cant believe I only used up about half a quart on this last trip.
The only engine related part I replaced before this trip was the PCV and the vacuum hoses that touch it.
WOW! Great Info Here!
  #57
Old 07-14-2011, 03:41 PM
stephen44 stephen44 is offline
stephen44 is starting off with a positive reputation.
I was burning so much oil i was getting quotes for an engine replacement !!!!
I had already checked the PCV - it passed the rattle test - but decided to replace anyways as it was $3.90 vs $7000
Guess what - oil consumption dropped to an acceptable level
So I would recommend everyone to swap it at the next service - just in case - what's $3.90.
BTW this is the heated one on a 2001 V10
- Stephen
  #58
Old 07-15-2011, 07:36 PM
housedad's Avatar
housedad housedad is offline
housedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputation
- Stephen
excellent!
  #59
Old 07-17-2011, 10:55 AM
Shilohii65 Shilohii65 is offline
Shilohii65 is starting off with a positive reputation.
Yeah, I was sold two smaller, bare metal pcv valves, and told "there are two on that model." Last time I will FULLY rely on the parts guy at a retailer to inform me of what my parts are. I found the valve mentioned above (the larger, blue plastic, twist type), and found that O'Reilly's carries the part for $23.00. I'll go pick one up today. Thanks for the conformation here.
  #60
Old 07-17-2011, 02:51 PM
Cardiac69's Avatar
Quote:
Rock Auto shows the PCV for less than $4. What does O'Reilley's include for $23? Some of the hoses?
02/PCV-Bad Mileage-strange g3ride69 Explorer, Sport Trac, Mountaineer & Aviator 2 03-24-2016 05:56 PM
sluggish acceleration in 4.6 Aviator 78_79ford Explorer, Sport Trac, Mountaineer & Aviator 29 08-28-2015 05:24 PM
PCV/Breather. cstephens Ford Inline Six, 200, 250, 4.9L / 300 15 11-08-2014 10:27 PM
Oil in the air box & PCV replacment on 08 5.4 08F1Tizzy 2004 - 2008 F150 1 11-15-2012 08:41 AM
02 Escape PCV, cranckcase vent oil seperator Oil leak Battman76 Escape & Escape Hybrid 3 02-02-2012 07:50 AM
Tags
10, 2000, 2001, 2005, 2v, 54l, 68, control, excursion, ford, inline, location, pcv, picture, sway, v10, v3, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
