integrated trailer brake controller - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-30-2010, 09:20 PM
kylebryan kylebryan is offline
kylebryan is starting off with a positive reputation.
I have a 2008 f-250 with the integrated brake controller and when i hook it up to my trailer it wont come on. When i manually slide the slider to activate the brakes it activates the brakes on the trailer. I checked the wiring all the way back to the brakes and everything is good so im not sure whats up with it. Just weird how if i manually engage the brakes it says "trailer disconnected" but still activates the brakes. Any ideas?
Old 08-30-2010, 09:38 PM
alchymist's Avatar
alchymist alchymist is offline
"Mifflin Clay"
alchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to behold
First guess - poor ground in trailer. Check the ground pin in the trailer side connector (plug) to be sure it's really grounded to the trailer frame and making good connection to the pin in the truck socket..
Old 08-30-2010, 09:43 PM
Quote:
I actually just put a new plug on th trailer wire and sprayed out my plug on the bumper with contact cleaner. the lights and everything work like a champ its just the brakes that dont activate the controller.
Ive been thinking its the ground too because i was pulling my 5er the other day and it came on for a few minutes and worked just fine. then it started blinking off an on. this is starting to get old....
Old 08-31-2010, 01:54 AM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
are you sure the brakes are connected to the correct pin on the trailer side?
...are you sure that your manual slider is actually braking the trailer? What you described will happen even if no trailer is connected.
Old 08-31-2010, 10:23 AM
fireman28's Avatar
fireman28 fireman28 is offline
fireman28 is starting off with a positive reputation.
Mine does the same thing. One of my trailers it shows everything is fine(newer trailer) on another it shows disconnected but they work. I have had it in show 3 times to figure it out and no luck. New magnets, new plug, and wiring confirmed. It does this on both of my trucks with factory controllers, but if I hook it to my 150 with a P3 controller it works fine. I think it is just an issues with some of the brake systems on some older trailers. I don't worry about it because they do work even when it shows disconnected. Just my .02
Old 09-01-2010, 01:57 PM
Yes im absolutely sure its connected correctly. And how do i know its braking you ask? Well, when i slide the slider it stops the truck. duh! The controller just isnt coming on when the trailer is hooked up.
Old 09-01-2010, 03:51 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
I hope you are not depending on the trailer being hooked to the truck thru the hitch as your ground! This is the most common problem. Unhitch the trailer from the truck, then see if you still have running lights on the trailer.
If no, you need to run a heavy gage ground wire thru the 7-way plugs. Or check the electrical plugs for rust/bad ground. Esp on the truck... water seems to corrode the wiring on the truck end INSIDE the connector.
Old 09-01-2010, 03:56 PM
thomabb's Avatar
thomabb thomabb is offline
thomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to all
Some older trailers have substandard wiring. The gauge of the wire is too small causing the controller to think there is a poor or no connection. The no-frills controllers will work on these trailers, but the high end ones with diagnostic capabilities go stupid.
Old 09-01-2010, 07:23 PM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Seriously, it is usually the ground connection at the trailer frame. Check it and clean it, then reattach and coat with some grease or Vaseline.
Old 09-01-2010, 07:32 PM
ISUsuperduty's Avatar
ISUsuperduty ISUsuperduty is offline
ISUsuperduty is starting off with a positive reputation.
Same thing is happening on my truck, '08 F-250. What I have read on this issue is that water will get into the back of the 7 pin connector on the truck side. You can remove the harness from the bracket (that the trailer plug mates to) and inspect for water / corrosion. Unfortunatley I haven't been home to try this out and see if it works myself, but it's one of the first things I'm doing before hooking on the the trailer. If it's happening on two trailers, I'd say it's the truck. From what I've read, and what others have said here, is that these TBC systems are very picky to corrosion and other wire issues.
Best of luck and let us know, there are plenty more with this problem.
Old 09-01-2010, 09:38 PM
RV_Tech's Avatar
RV_Tech RV_Tech is offline
RV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputation
Did you ever try an "ohm the brake leads on the two trailers and compare resistance. I'm just curious as it seems like this must be a connection issue somewhere.
Steve
Integrated trailer brakes active when truck not running Jansarchie Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 17 10-07-2016 04:43 PM
Integrated Brake Controller weak? vectrex Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 21 06-19-2014 12:52 PM
Integrated Brake Controller Problem Cajuncru 6.7L Power Stroke Diesel 19 08-16-2012 08:43 AM
2008 Integrated Brake Controller igotjam Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 16 11-09-2007 08:11 PM
Issues With Tow Command Brake Controller aseifert 1999 to 2016 Super Duty 6 04-14-2006 10:43 AM
Tags
2002, 2008, brake, brakes, controller, design, disconnected, duty, electric, f250, ford, integrated, plug, super, trailer, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
