460 pics
Looks like mid to late 70s car, especially if that is a GM A6 compressor hanging over beyond the power steering pump. It could even be earlier, I pulled some stuff off a 72 Lincoln that had that setup. My 71 Colony Park 429 was similar, but had a York 2cyl compressor, and I think some of the brackets were different. I sold the car in 1995, and had put the Lincoln automatic climate control in the wagon along with the dashboard.
on
The fans are off of a 2000 Chevy Malibu, bracketry as you can see if just angle, total overkill but I don't like the typical aftermarket push the plastic pin through the fins setup...
It bolts to the lip on the top of the rad and the lower brackets sit in the clips for the bottom of the fan shroud.
I have a few taurus and Windstar fan setups laying around, but the Malibu fans keep the 460 happy on the trail, and would probably be plenty for a highway rig.
does anyone have anyone pics of a fuel injected 460 or the serpentine system installed in a 77-79 f250 4x4, i am building a 78 crew cab long box 4x4, the frame is from a 78 supercab, i have the l and l motor mounts, i am using the brackets and everything off of a 1990 f250 4x4 and my alt is in the right spot and everything but i tried putting my a/c and power steering bracket on and the power steering pump and bracket hit the steering gear, i thought about notching the bracket but that still doesn't fix the pulley, i have seen a few other guys have done this but they never put pics of what they did or even said what parts they used, any info would be greatly appreciated
Andrew Ford
10-18-2016 06:50 AM
norvillebob
07-07-2016 01:37 PM
96 high boy reboot
11-23-2015 02:30 PM
96 high boy reboot
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
11-04-2015 01:08 PM
Jam21
03-21-2012 07:17 PM
