oil consumption
Not sure what "normal" is... I have 109K on the 2004, don't usually add any oil between changes. It has been very well maintained since new.
And... I thought that I would be the only guy on FTE forum with a GN (I'm too new to rate a signature... likely won't list the GN in there anyway).
We have an 87, T-tops, 23K miles, basically all original/stock.
Where are you located? I'm in southern NJ - Philly suburbs - MAGNA territory.
Mark
Mark
I do 5k oil & filter changes, as well, and my 5.4 has been known to use zero oil and a quart of oil in that time frame. I've heard and read that the Tritons were designed to use a little oil. I'm at about the 3k mark since my last change, and the level is still at the full mark with nothing added since the change 3,000 miles ago. I wouldn't worry about it unless it becomes really excessive.
Depends on my driving Normal, around town driving, no trips into the mountains and my truck will use almost no oil. If I start driving it harder, passing cars, towing in the mountains or just in a hurry to get over the pass, mine starts sucking down oil. I do 5k mile changes with Motorcraft oil and filters. If I have been working it, adding one to one and a half qts between changes is normal for mine at 138k miles.
I drove a 99 F150 company truck with 250k miles on it and that one, neglected from new, burned a qt every 2000-3000miles.
Typically one qt per 1000 miles is considered "normal". The only problem is, what are you going to do if your truck uses some oil? New engine? Different truck? It isn't like there is an easy fix. I personally wouldn't sweat it, just check the oil more often.
Teamlx88 - I thought that you were trying to find out actual the experience of other 5.4 engine owners on this forum... sound like there is a range of usage.
Good luck with the sale of the GN... do you post on any of those forums? (at least 2 have "Cars for Sale" areas, segregated by section of the U.S.)
Mark
That is the line the dealers are required to sell lately. Back in the days of really high horsepower cars 1 qt. per thousand was accepable only on those factory hot rods. Normal cars and trucks got the engine re-ringed or replaced for that high of consumption.
My previous 2000 F150 5.4L would use a quart or so between oil changes. I ran 10k between oil changes using Amsoil 5-30. Did that from the time I bought it with 23k on it till I traded it at 109K.
The 2004 Expedition 5.4L I traded the truck for does not seem to use any oil between changes. Running 10k between oil changes using Amsoil 0-20. 103K on it currently.
Oil usage, I believe for the most part, varies because of the manufacturing tolerances of the engine. (of course if the engine has not been maintained it will burn more oil) If it doesn't burn enough oil to smoke, just make a habit to check it every 3 or 4 tank fulls of gas and keep on truckin.
Ran up over 1500 miles in the last 2 weeks, mostly with the Tiger on the [open] trailer. Computer claimed 13.3 mpg, actual calculation shows more like 12.8 - not bad, all considered. Odometer currently at 111K.
I di not see any difference in the oil level during or after the trip
Mark
2004 Expy EB 5.4 4x4
Mark
79beater
18
03-29-2020 02:39 PM
