Map light/Courtesy light - Ford Truck Enthusiasts Forums
Old 08-30-2010, 01:46 PM
fdh fdh is offline
fdh is starting off with a positive reputation.
New Guy with New (used) truck. Picked up a nice 1990 ford f150 4x4 4.9 litre with 5 speed. Just a little help with the map lights that have 2 switches. Do they only work with the key on. Courtesy light seems to work fine. Bulbs ohm check good.
Old 08-30-2010, 02:30 PM
F150xlt F150xlt is offline
F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.
Here's the map lamp schematic for a 88 which is probably the same for your 90.
The Dome lamp bulb and the two map light bulbs get 12 volts from the same
source which is Fuse #8 and is hot at all times.
The route that the 12 volts gets to the dome light is as follows.
Either thru the right hand or left hand door jam switch or the headlight
switch when it's rotated all the way counter clockwise.
The Map light witches get 12 volts to one side of them at all times via a
Light Green/Yellow wire from Fuse #8. When the switch is turned on,
the 12 volts goes thru the switch to one side of the bulb. The other side of
each bulb is tied to ground so the bulb lights up.
If you remove the black plastic trim piece that covers the interior rocker panel
and holds the carpet edge down you should see the Light Green/Yellow wire and
measure 12 volts. Or you might have to remove the rear plastic trim panel to
get a look at the wire as it goes up the back side of the cab up to the map lamp
switch.
On my vehicle, the wire eventually broke at that area because there was not
enough slack in the wire.
Old 08-30-2010, 02:34 PM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
Mine work with no key at all.
Old 08-30-2010, 02:46 PM
jplinville's Avatar
jplinville jplinville is offline
jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.
To make it simple, yes...the key needs to be on to turn the map lights on. Not true for the dome light, as it should turn on when you either open the door, or rotate the headlight switch. Also, the keys need to be on to turn the bed light on as well.
Front Courtesy door lights and dome lights don't work JJONES7432 Explorer, Sport Trac, Mountaineer & Aviator 6 11-10-2015 03:22 PM
2003 Lincoln Navigator RDockery 1997-2006 Expedition & Navigator 2 07-05-2015 11:52 AM
Courtesy Light 73fan 6.4L Power Stroke Diesel 0 10-09-2014 09:34 PM
Fuse help please 2civicrr 6.0L Power Stroke Diesel 3 02-03-2014 07:00 PM
Door Courtesy Lights MAD80433 1997 - 2003 F150 0 08-22-2009 02:37 AM
Tags
1992, 1996, bulb, courtesy, cover, f150, f250, ford, lamp, lense, light, lights, make, map, replace, replacement, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
