Engine break-in on highway?
Hi all -
Bought a new SD that is located almost 600 miles from home. Does anyone have any advice on break-in? I've heard you do not want to keep it at the same speed constantly (ie, highway miles), but is just varying my speed on the interstate between 55 mph and 75 mph every 25 miles or so ok? Or do I need to stop off in some towns and do some start and stop driving?
It won't matter. There is no break-in period on engines today. Ford recommends a break-in period before you tow, but that is for the differential gears, not the engine.
Just get her home, and then do a fair amount of combined city and highway before you pull any heavy loads. You'll be fine.
The easy way is to just change gears, my understanding of the 6 speed is you an select gears so run it from 3rd all the way to 6th on the highway and you can vary the rpms and not be varying the speed so bad. I would take it a bit easy for the first 100 miles or so then drive it however you are going to drive it and I run them up to redline well before 1K miles.
My08F250FX4
6.7L Power Stroke Diesel
07-05-2010 09:51 AM
