1978 - 1996 Big Bronco
89 Bronco for 15 year old step son to fix, need help.
Old 09-03-2010, 11:49 PM
C-lint's Avatar
C-lint
C-lint is offline
Smile
Thank all Y'all very much. And the reason i did not check my plugs is because they had like less than 50 miles on them. BUT i guess they was bad. i am gonna take them back to autozone tomorrow. get my money back out of those motorcraft platnum plugs. lol
  #32
Old 09-04-2010, 12:58 AM
kenjh's Avatar
kenjh
kenjh is offline
do a compression test on the cylinders that are fouled..if the compression is good you may have the valve stem seals breaking down , and this is gonna happen again.seals are cheep if you use the umbrella type ,the better one are the vitron spring style . but I think you need the valve guide machined for them..
  #33
Old 09-04-2010, 04:32 AM
Black Ford XLT's Avatar
Black Ford XLT
Black Ford XLT is offline
Clint , i would still change the pick up coil, my 85 would do great untill it got hot and died at 50-60 mph.TR
  #34
Old 09-04-2010, 09:49 AM
C-lint's Avatar
C-lint
C-lint is offline
Thumbs up
[quote=kenjh;9291870]do a compression test on the cylinders that are fouled..if the compression is good you may have the valve stem seals breaking down , and this is gonna happen again.seals are cheep if you use the umbrella type ,the better one are the vitron spring style . but I think you need the valve guide machined for them..[/quot
Thats not that bad of an idea. But the thing was rite when i put those (50 mile) new plugs in it started doing it AS soon as i hit like 45 or so. So they still didnt have a chance to be fouled yet i dont believe. Its a great bronco. Heck, i paid 400 bucks for it and other than that messing up its been great. and it obviously still runs like a champ because i have never ran it that hard till yesterday. and it still seemed like it had plenty more power even sitting at about 100. and this is the C6 3 speed. lol. So if it does need new valves i am gonna go ahead and and have the heads ported and polished also....
  #35
Old 09-04-2010, 09:52 AM
C-lint's Avatar
C-lint
C-lint is offline
Thumbs up
heck, i will go ahead and do that also. There is no point in me replacing the WHOLE ignition system and not that pick up. lol. so im still gonna go buy the dist. off that donor van for just in case purposes.
  #36
Old 09-04-2010, 03:40 PM
75Three90's Avatar
75Three90
75Three90 is offline
sounds good clint im still having issues with my truck POS 5.0 LOL naw its a good motor just noone has done maitnece on it in like 4 years so its left up to me i pretty much have to run new vaccume lines and find out what a part is lol
  #37
Old 09-04-2010, 06:56 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
Take a picture and point out the part, we'll tell you what it s.
  #38
Old 09-04-2010, 07:19 PM
75Three90's Avatar
75Three90
the vaccume line connects to the throttle body runs through this then goes to the new style ford canister on the frame
  #39
Old 09-04-2010, 08:35 PM
greystreak92's Avatar
greystreak92
greystreak92 is offline
The item in the photo being the canister purge solenoid.
  #40
C-lint's Avatar
C-lint
C-lint is offline
Post
Does that part have a sensor or any type of wires running to it?
  #41
Old 09-04-2010, 08:37 PM
greystreak92
Yes, two-wire connector. The computer controls its operation.
  #42
75Three90's Avatar
75Three90
ok wits making my motor over rev BAD at start up till i get it in gear can i bypass it, unhook it and block the line or run a straight line to the charcoal canister
Keithfriend
13
06-19-2014 11:18 PM
runstang22
2004 - 2008 F150
08-08-2013 07:29 AM
bubbasz1
1999 to 2016 Super Duty
03-15-2009 08:53 AM
johare
1983 - 2012 Ranger & B-Series
06-08-2007 01:11 AM
1966Tbird
05-21-2007 06:42 PM
Quick Reply: 89 Bronco for 15 year old step son to fix, need help.
