98 F150 Intake Manifold Runner Control valve problem - Ford Truck Enthusiasts Forums
Old 08-30-2010, 12:46 AM
kbgrn150 kbgrn150 is offline
kbgrn150 is starting off with a positive reputation.
My 1998 F150 4.2L V6 145K miles has developed a stuck open Intake Manifold Runner Control Valve OBD code 1537. Has been suggested by mechnic who attempted to conduct annual inspection that it is likely gummed up with cabon based on their experience. Looking for the does and don't of repair/replacement of the IMRC from those who have done this before. Thanks in advance for any and all helpful replies to this post
Regards
kbgrn150 <!--IBF.ATTACHMENT_50615-->
<!-- THE POST -->
<!-- / message -->
Old 08-30-2010, 06:56 PM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.
I remembered a thread from several years ago and dug it up. Maybe some help...
http://www.ford-trucks.com/forums/50...-acuators.html
Try using the search feature on the top task bar, searching for your code or "IMRC" or "runner control".
There is some info there, just nothing recent as the IMRC setup has not been used for several years now.
Hope you get is squared away.
Old 09-06-2010, 09:17 AM
bokker bokker is offline
bokker is starting off with a positive reputation.
hi, if it is the vacuum type check the pipe work for leaks and check that the lever arms have not come off the activators. if not sure suck on the rubber pipe and you will hear the flaps open and close all with the engine turned off. hope this helps bokker.
Old 09-15-2010, 12:01 AM
ottawaguy's Avatar
ottawaguy ottawaguy is offline
ottawaguy is gaining momentum as a positive member of FTE.
Quote:
x2...and you are right bokker 97-98 were vacuum control.
Old 01-26-2011, 11:17 PM
dod dod is offline
dod is starting off with a positive reputation.
same problem with 4.2l
Quote:
Regards
<!-- THE POST -->
<!-- / message -->
New to this site I hope you fixed your problem? I've recently come upon the same problem will be working on my IMRcv friday hopefully I'll solve this its been a tough one won't pass smog runs great except at lower rpms slightly sputters just enough to give a high CO2 reading to fail it. So I either I replace the 1 bank IMRC with a used one from the junk yard or buy a new one. I've tried seafoam replaced the dpef valve,EGR valve, vaccum control breather valves almost anything that would cause the code 1537 and engine light still came back on as you might guess this has been costly mechanic fees and parts killing me I'll check to see if they can be opened up and cleaned keep you informed if you have any thing please hit me back.
The DOD
Intake Manifold Runner Control Malfunction (stuck Open) Code 1518 tgaf150 1997 - 2003 F150 6 01-22-2012 06:25 PM
98 F150 Intake Manifold Runner Control valve problem kbgrn150 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 08-30-2010 12:54 AM
4.2L Emission Troubles F150dude619 3.8 & 4.2L V6 3 11-25-2002 12:58 PM
Intake Manifold Runner control big60 1997 - 2003 F150 1 11-09-2002 08:19 PM
intake manifold runner control davisr9 1997 - 2003 F150 2 08-28-2002 09:29 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1999, 2003, 42, 42l, actuator, control, engine, f150, ford, imrc, intake, manfold, manifold, runner, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
