460 air pump delete - what belt??
Old 02-17-2003, 06:35 PM
Pilgrim's Avatar
Pilgrim
Pilgrim is offline
Hi all. I've got a '92 F250 with 460 engine. I want to delete the air pump. Has anyone else done this? I need to know what belt to buy. The other one will be much too long once I remove the pump. Thanks to anyone who can help with a length or part number.
Pilgrim
Old 02-17-2003, 08:30 PM
shotgun's Avatar
shotgun
shotgun is offline
Just remove the original belt. Now take a peice of string and run around all the pullys minus the air pump. Measure the string. In my case the belt I needed was about two inches less than the string length. To give the tensioner enough room to take up the slack.
On my 300/6 with the air pump still on, I had to remove one bolt and grind the head down much flatter so it would not rub the new belt route, so check for that.
Just tell Auto Zone what you want to do. They don't have any problem taking back one belt and trying another. And are pretty good at matching belts by inches. Atleast where I live....
Old 02-17-2003, 08:57 PM
CrazyFordMan's Avatar
CrazyFordMan
CrazyFordMan is offline
what did you all have to do to remove the pump like what did you have to block off or remove and what gains are you going to get from this?? better milage power??
Old 02-17-2003, 09:11 PM
Pilgrim's Avatar
Pilgrim
Pilgrim is offline
shotgun: thanks for the suggestions. I'm not close to anything like Autozone. I'll maybe have to do it by measuring. Just thought someone must have already done it...?
CrazyFordMan:Not sure what gains, if any. I'll get. My convertor was plugged and restrictive so I removed it and installed a new dual 2 1/2" exhaust. With the cat removed, the air pipes are just hanging and blowing underneath the truck. Just a lot of pipes and junk rattling around down there, and the pump turning all the time. Don't suppose it's sucking too much power, but whatever it is, I'm going to put a stop to!
Pilgrim
Old 02-17-2003, 09:15 PM
CrazyFordMan
wont the O2 sensor thro a code and tell the comp to lean out the mixture cuz it wont be getting enough oxegen
Old 02-17-2003, 09:30 PM
Pilgrim's Avatar
Pilgrim
Pilgrim is offline
CrazyFordMan: hasn't yet (thrown any codes, etc.) in over a month and a few thousand miles.????
Old 02-17-2003, 09:35 PM
CrazyFordMan
hmmm i just might have to try this i did on my 400 but i though that it would screw too many things up with my new one being all computerized
Old 02-18-2003, 05:45 AM
rabidranger's Avatar
rabidranger
rabidranger is offline
If pilgrim's truck is like mine he won't get any codes because the O2 sensor is before the cat... Some retarded years had an o2 sensor before AND after the cat to monitor proper emissions. You will also have to plug the pipes on the exhaust manifolds too.
Old 02-24-2003, 10:00 PM
Pilgrim's Avatar
Pilgrim
Pilgrim is offline
In case anyone else with a 460 is interested, the correct belt for the air pump delete is Dayco #5060475. Now you can go buy the belt and have it when you do the removal instead of having to go once you get to the replacement belt step. It's hard to accurately measure it first, since the pump is in the way of the new belt route and there's a limited amount of "tightener".
Old 02-25-2003, 01:59 PM
mike460's Avatar
mike460
mike460 is offline
hey i used a kelly springfield 470K6, basically the same belt as mentioned in the above post....47 inches long, 6 rib. worked great
mike
Old 03-16-2010, 06:13 PM
LloyDana460's Avatar
LloyDana460
LloyDana460 is offline
THX Pilgrim... THX Mike...
Matt
Old 03-16-2010, 07:28 PM
95F150Guy's Avatar
95F150Guy
95F150Guy is offline
Not trying to highjack your post, but I was wondering what the part # is for a 95 5.8 without the pump?
Old 03-16-2010, 07:32 PM
Jeff Dodson's Avatar
Jeff Dodson
Jeff Dodson is offline
well I can tell you there is NO (ZERO) gain unless your pump is locked up up something like that, They free spin. I removed mine because when I put the headers, I had to cut the air pipes because they were rusted on there. Anyway, Mine is a 351W (5.8) so I dont think the size of my belt will do you any good
Old 03-16-2010, 07:48 PM
95F150Guy's Avatar
95F150Guy
mine is a 95' 5.8 351 W too, I am getting rid of because I'm going to run true duals.
Joe
Old 03-16-2010, 07:57 PM
Jeff Dodson
Joe
well yours will probably be the same as mine. I had to force it under the idler pulley after the alternator, only because I knoe the tensioner was going to help the belt stretch some. It was tight but I got it on. BTW, I only use GATES BELTS and HOSES. There arer the best on the market
Quick Reply: 460 air pump delete - what belt??
