460 air pump delete - what belt??
#62
exhaust pic's
well, got the Y pipe repaired, muffler shop made a new end for the 1 side to bolt to the exh.manifold. ( new stud kit / dorman, i got at advance auto with brass nut's even ) swapped cat out for a piece of 3" i had from NOS-IHC stock i had laying around, got it to fit, clamped together , then fired the ole girl up an damn, if my manifold gasket ain't leaking. i kinda figured if i got it all solid that it'd find a weak spot. just barely though. but i think i can access the exhaust manifold by taking the dog house/engine cover off, since it's a 460-in a coachmen M.home. belt does squeal a bit on start up for a lil while, i guess to stop that would be to put on a belt tensioner. but it don't bother me all that much, once warmed up it quit's. FOUND 2 broken exh.manifold bolt's. and the 1 ahead of the rear, near # 3 cyl., is broke off inside the head, past the gasket surface. that will have to wait till spring time, R & R head's. can't get a drill in there, might be able to if i unhook the engine mount's and jacked up the engine. that's a warmer time of year job. it sealed up after warm up.
#63
I just did this to my 89 MH along with the cat delete..My old motorhome is like a new girl. Great thread with lots of great info
#64
OK guys, I'm building a '53 C500 with a '96 EFI460. The "S" shaped throttle body elbow is sticking up in my floorboard more than I want. I've found a low profile Holley throttle body kit that replaces all of that but I'm wondering about all the other stuff. I'm going to move the coil off the valve cover. Can I remove the EGR and all of the air pump lines without the '96 computer freaking out? I won't have a check engine light to worry about, I just want it to run good. Thanks in advance,
Ken.
Ken.
#65
Ken.
Ken.
#66
I know this is an old thread but just FYI this flange is still sold on eBay and also fits the 460 engine.
Now that's GREAT news!
Can't tell you how many times (I'm mostly in the 7.3L diesel forum) I've had someone tell me something and it seemed impossible for them to know, but...LOL
Here's what I just received today: Catalytic Converter Repair Flange Fits 87 99 Ford F250 F350 E250 E350 5 8L | eBay
The description says 3" outlet, I think the exhaust is 2.5", but I'll know more in a day or so.
$37.05 with tax vs MUCH, MUCH more from other sources...and the flange gasket is included!
My plan is to measure everything up and temporarily install a straight pipe from the flange to the muffler and run it this way until we're sure we addressed all the other issues. No sense killing another cat
Once we're satisfied we, being the responsible citizens we are in spite of being emissions exempt, will purchase an aftermarket cat in the sub $100 range instead of the $400-$600 to replace the one with the inbuilt flange.
If anyone is interested, I can take pics and parts and stuff, just in case anyone else needs to setup a "test pipe"
#67
#68
1991 E350 EFI 460 air pump delete
great threat about to delete my air pump and cat on my 91 E350 C class rv. Tons of info in this thread. Any tips or things I should know would be great. Thanks
#69
I know this is an old thread and I am new here. I am working on restoring an 86 Ford F250 with a 7.5L 460 back to function and one of the things bad on it is AC. There is no belt and it looks like the Air Pump/Smog Pump has been fully removed. I've been searching for belt routing yet haven't found anything. Anybody willing to post pics?
Here in Utah, since the truck is over 30 and will be used in a reserve capacity, it qualifies for vintage plates. Vintage plates means it legally doesn't need to pass emissions either. Instead, I'm using it to help my kids understand how a standard transmission works and to get experience with a larger vehicle. It also allows me and a few neighbors to have hauling capacity and such. I hope to get the AC fixed. First thing is to see if the existing assembly works or if the belt was removed because the Smog pump was removed and tension pully is seized. If the ac compressor is bad, then I'll look to replacing it.
"Fun" times. Previous owner really didn't take too good of care of it, yet I guess it helps to learn a few things...
#70
O, welcome to FTE
you may have better luck posting in Bullnose section-->1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
#71
Check this post. Should answer all questions on a 460 air pump delete.
https://www.ford-trucks.com/forums/1...l#post19802026
I've got about 3,000 miles since the delete, including towing our 5th wheel several times.. Zero issues, no CEL. Truck runs perfectly.
#72
Yet pulling the 460 out and attempting a rebuild seems a bit beyond at this point, at least for now. She has four engine related issues at present though:
- She leaks a little oil off of both her oil pan and her valve covers. I say "a little" because it isn't enough to really require additional oil added very often. But then, she isn't driven very often.
- At idle, she often sounds like she's about to die, especially after initial start, and sometimes does. Doing research, I suspect vacuum issues but haven't gone through all the plugs yet to see if it might be there.
- AC is unattached/unpowered and compressor is easy to spin (told that means it lacks freon and will require conversion, one step at a time though, need to get her spinning)
- She is leaking something else, and it looks like power steering fluid. Comes off of the forward axle.
In addition, I am trying to recondition the interior. Previous owner snapped both the cables for accessing the back area (extended cab) and I was able to find replacements (one damaged) in a junked truck at a pick n pull. The back area still needs A LOT of work. Console lights are dim and probably need replacement. Radio was removed and harness cut. The shades hang down (bad springs) and the back seat seems to need a replacement spring too... back window latch is missing and it looks like it was caulked into place. There is an unknown "switch" installed near the steering column by the trailer brake, still wired, no idea what it is. Tow hitch assembly is in unknown state, spare tire rack is in unknown state (spare tire is in bed)....
Country boys and the way they sometimes treat their trucks..... At least I'm LEARNING a lot from her!
#73
on
I also had a bad CAT last summer.
Removed exhaust from the large rectangular Crossover Flange (for the CAT) on back.
Got two 30-degree elbows for 4" pipe and welded them to the replacement CAT flange then ran an APE Power 4" diesel exhaust I located on an salvaged F350 7.2 IDI.
I do have a loud drone issue to sort out, which I anticipated.
I too will remove the remaining smog pump and hoses.
the390feking
04-21-2020 03:20 PM
gman97005
11-21-2013 03:11 PM
DJdemon6696
09-05-2009 10:29 PM
BTSNPCS1990
03-31-2009 11:48 AM
