Cheap safe ways to lift body's off frames. - Ford Truck Enthusiasts Forums
Old 08-29-2010, 10:01 PM
FarmerBill's Avatar
FarmerBill FarmerBill is offline
FarmerBill is starting off with a positive reputation.
Well guys , Trying to fore see how i'm gonna lift my cab/ box of with out smashing stuff and me. the place I'd rather work on my truck.. has a bobcat. but nothing thats actually high up to lift the big parts off. And ideas? If not i'll be doing the work at a different place, and i'm not sure how often the owners gonna be there to help out lift with his big machinery. Idea's pics explanations all welcome thanks folks
Old 08-29-2010, 10:09 PM
dynamic's Avatar
dynamic dynamic is offline
dynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to behold
4 buddies and a case of beer!!!
Old 08-29-2010, 10:18 PM
FarmerBill's Avatar
Well maybe you an i an two alike haha but i'm a bigger guy my friends aren't. well the one's that will probably show. Plus both frames trucks have suspension lifts. frame i'm using has the 3 inch.. and frame of truck i was gonna use is a 6 inch lift. The good cab i'm using will have full clip still attached. and i plan on removing the poor cab+clip together as well. like i said.. i know the bob cat can lift it weight wise.. but its not very agile right. and isn't tall enough to hang over top and lift up. hmm
Old 08-29-2010, 10:26 PM
thatsrealnice's Avatar
thatsrealnice thatsrealnice is offline
thatsrealnice is starting off with a positive reputation.
get 4 or 5 friends to help you. lifted the bed off the donor truck and carried it about 50 feet to my truck there were 5 of us to do that, i wasn't much use, i'd just had surgery. they're not really that heavy. same goes for the cabs, jack up the cab, get some 2x4's and slide them through to the other side and lift the cab using the 2x4's as handles
Old 08-29-2010, 10:27 PM
Witty73's Avatar
Witty73 Witty73 is offline
Witty73 is gaining momentum as a positive member of FTE.
I have swapped numerous cabs. They can be moved around quite easily with you and 3 of your buddies. If you dont have buddies available, you can roll the windows down and use a heavy yellow ratchet strap. Loop it though the windows, and over the top of the cab and hook the ends together. slide it up towards the vent windows and ratchet it tight. Now you can hook on with an engine lift or cherry picker and pick it up. I have done this numerous times. I have done it with both a stripped down cab without doors and windows, steering column, etc. I have also done it with a complete cab, but you have to be a little more careful because of the extra weight.
Old 08-29-2010, 10:38 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
the pros use a cherry picker attached to a lifting frame to remove the bed. It's basically a "H" frame with the ends going under the bed lip. The cross bar of the H is where the cherry picker is attached. Lift slowly and adjust to find the center of gravity.
As far as the cab, A DIY method is to first raise the bed off the frame by installing wood spacers (like stacked 2x4s) and then insert long 2x4s crosswise and then nail those together to create a cab pallet. Once the pallet is built and supported, raise the cab and then the frame rolling chassis can be moved out.
Okay, so now the cab is up in the air and the frame is out the door... build a cab table (with wheels) so the cab can be lowered/moved on top of it - three friends, a case of beer, and two large pizzas.
Old 08-29-2010, 10:49 PM
FarmerBill's Avatar
lol thanks folks comedy an idea's both.
Old 08-30-2010, 12:19 AM
Flat_Ford Flat_Ford is offline
Flat_Ford is starting off with a positive reputation.
i have a 4x8 flat trailer that sets pretty low. i'm usually by myself. just me and the pregnant girlfriend so she can't do much lifting but i usually use a 2x4 to pry it off and a rachet strap somewhere sturdy and she can ratchet while i'm pushing and wiggling trying to get everything loose....
idk if pizza and beer would do it for my friends...they're all kinda lazy.
Old 08-30-2010, 10:00 AM
Joseph69's Avatar
Joseph69 Joseph69 is offline
Joseph69 is starting off with a positive reputation.
Get two 4x4 posts 10ft long, jack the body up a little, put the post in from the side. Get 4 55 gallons steal drums and some shorter wood blocks for a little more height. Put the drums out far enough to roll the frame out. I've done this with a supercab on 35s and had enough room to back my car trailer underneath the cab and put it on the trailer.
Old 08-30-2010, 10:01 AM
hillbilly469's Avatar
hillbilly469 hillbilly469 is offline
hillbilly469 is starting off with a positive reputation.
I've always had to do everything by myself ( I don't drink so the beer thing never works. lol) I have always used 4x4"s under the cab and bed letting the ends rest on blocks outside the wheel width. I raise and add more blocks one side at a time until the body clears chassis and then just roll the chassis out from under the body. Works great and best of all you can do it without any help. You have to be careful to slide the 4x4 that supports the front of the cab as far forward as possible because the extra weight makes it front heavy and could roll forward if placing isn't correct.
Old 08-30-2010, 10:44 AM
Joseph69's Avatar
With you on the do it yourself. For the bed I took a 4x4 post and two 2 x4s and wide as the underside of the top rail, and four 2 foot long 2x4s. Nailed it together like this...
Front of Bed
.......| Hook lift here
Tailgate
Then lifted it off with a chain fall
(ignore the dots, text wont show leading spaces )
Old 08-30-2010, 11:31 AM
FarmerBill's Avatar
ah ic .. ok no that sounds good. And as long as i get the blocks up high enough i'll be able to put the post's under it , far enough forward. good idea.
Old 08-30-2010, 03:14 PM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
I wanted to build a gantry to hold a chain hoist for stuff like this, but then I realized I don't have a garage or even a paved driveway. so what I've been thinking about is buying a beat up used trailer or just a trailer axle, and building one onto a trailer axle with an I beam sticking out 6' off the back with a 2" hitch on the front so I could hitch it onto a truck for weight, and then pull the cab (or motor or whatever) up with the chain hoist and use a trolly to slide it back and center the weight over the axle. If I did this, then I could move cabs and engines and stuff way easier since I have a couple different trucks in a couple different places. It would be a good winter project. We'll see!
Old 08-30-2010, 03:21 PM
doug70 doug70 is offline
doug70 is starting off with a positive reputation.
I have done this by using 4x4 posts and jacking the body/bed up and rolling the chassis out from under it. Haven't done that since I put a gantry crane in the welding shop.
Doug
Old 08-30-2010, 04:38 PM
highboy1975 highboy1975 is offline
highboy1975 is starting off with a positive reputation.
if you dont have a crane that will be high enough, get at least 3 other friends. really try for more. most of the weight is in the front of the cab. we rolled the old cab off, then stepped the new cab on from the side with help from a cherry picker. put one side on the frame, picked up the side on the floor with the picker, then passed it across to get it in place. good luck, remember, more people is better than not enough. its not that theyre super heavy, but they are awkward. also, remove as much as you can before you remove the cab. doors, glass, seat, carpet.....all add a couple pounds to what your lifting. if you have a high enough crane or whatever, wrap a srap under the front cab mounts, up under the cowl corners, and put a 2x4 or 4x4 in the top front corner of the door jam. wrap the strap under the 2x4 so it pins it into place when you put load on the strap, meet in the middle over the cab roof, and pick it up that way. it should pick straight up. remember, all the weight is in the front, so you want to bias any lifting points toward the front.
Leaf spring lift measurement arkredneck 1994.5 - 1997 7.3L Power Stroke Diesel 28 10-28-2014 08:45 AM
lowering ideas FordYoungGun35 1987 - 1996 F150 & Larger F-Series Trucks 13 06-11-2013 06:27 PM
F250 HD Front IFS to Solid axle conversion ness0012 1987 - 1996 F150 & Larger F-Series Trucks 37 01-20-2013 10:20 PM
just got a 03 e250 triton v8, any ideas how to improve mpg's?? D_Dillen 1968-2013 Full Size Vans 12 04-03-2011 01:16 AM
Big lifts for Dually f-350 4 door cab? ALEXVB22 Brakes, Steering, Suspension, Tires, & Wheels 13 04-30-2008 06:55 PM
Tags
1987, 60, body, cabs, cheap, cherry, crane, easy, f150, ford, frame, lift, overhead, picker, removing, truck, ways
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
