Dana 70 rear axle - Ford Truck Enthusiasts Forums
Dana 70 rear axle
Old 08-29-2010, 06:03 PM
junks junks is offline
junks is starting off with a positive reputation.
Dana 70 rear axle
I Have a 1985 f250, 6.9L, Dana 70. Can I use a Ford rear axle in this truck. If so, what do I have to look for. Thanks
Old 08-29-2010, 06:11 PM
oreocreaming's Avatar
oreocreaming oreocreaming is offline
oreocreaming is gaining momentum as a positive member of FTE.
by ford rear axle you mean sterling 10.25? either way yes, the u joints might be different size caps but other then that, your good to go.
Old 08-29-2010, 06:12 PM
it is 2wd right? if its 4x4 you gotta make sure the gears match or when you do throw it into 4x4 your gonna bind up and break something
Old 08-29-2010, 06:28 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
Where is the fill plug located?
The Sterling axle looks a lot like the Dana 70.
Dana axle fill plug in the rear cover.
Sterling axle fill plug on the drivers side of the pinion on the front of the axle.
Old 08-29-2010, 06:34 PM
greywynd greywynd is offline
greywynd is starting off with a positive reputation.
Also, make sure everything in the replacement axle matches, spring perch to perch measurements and backing plate, to backing plates can also differ, depending if it came out of a dually, cab and chassis, or regular truck.
1979 f250 custom 4x4 dana 60 rear swap dana 70 70 Dirtyweekender77 1973 - 1979 F-100 & Larger F-Series Trucks 7 11-10-2013 08:51 PM
axle splines vettman 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-12-2011 10:33 AM
Dana 70HD vs 70U...which is better highway90 Clutch, Transmission, Differential, Axle & Transfer Case 3 12-13-2005 11:31 PM
Dana 70 Left Handed Thread? Wrecker Clutch, Transmission, Differential, Axle & Transfer Case 8 10-04-2004 08:14 PM
Dana 60/70/Sterling 10.25 rear axle swap orange78oval 1978 - 1996 Big Bronco 1 01-25-2004 09:11 AM
Tags
1990, 70, axle, dana, differential, f350, fill, plug, rear, sale
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
