Dropped Bolt from HPOP Cover
I got a mirror and looked back in there best I could and couldn't see anything. I'm going to try to search some more before i have to yank the transmission. Also I have no access to a borescope so my options are limited. However my truck does have 185k on it so is there any thoughts on to what i can replace if i do have to pull the transmission. I haven't had any problems with it shifting or anything like that, just thought maybe I would do some preventive maintenance on what i have access to while I'm under it.
Visual Optics Video Inspection Scope 36" Borescope : eBay Motors (item 270628885081 end time Sep-06-10 08:06:40 PDT)
its a fiber optic camera we use to see in engine.
I would try to get the boroscope. It will save you a lot of time. I have seen these as cheap as $100 in Canada.
Where all can this bolt be inside of the motor. I believe it went between the gear and the block but I am not sure.
2006 F350 4X4
No doubt. I get everything i need to put this truck back together and drop the stc fitting bolt. I have the camera but I cant see it anywhere. I tapped the bottom of the oil pan to see if it would rattle in there but nothing.
2006 F350 4X4
There's another post going right now a feller dropped his torx bit down an injector hole--so he's going through the same thing. I sure hope it's in the pan and not stuck--not sure myself what all can stop the bolt on 4he back end--just stay patient as you have been so far.
2006 F350 4X4
2006 F350 4X4
#28
I am working on getting you some pictures. The best I remember is that in won't go down to the oil pan. The concern that I would have is if it didn't go all the way down. If its wedge in between the cam gear and the block or the cam and the crank wouldn't be good.
Mine didn't go all the way down. It must have been setting between the crank balancer and the cam gear.
Do you have an extendable magnet with a small head?
#30
