dive block dove heads - Ford Truck Enthusiasts Forums
Old 08-29-2010, 01:48 PM
tbird250 tbird250 is offline
tbird250 is starting off with a positive reputation.
will i have any problems running dove heads on adive block?
Old 08-29-2010, 05:54 PM
jwtimme jwtimme is offline
jwtimme is gaining momentum as a positive member of FTE.
no they are only one year apart dove 70 and dive 71
Old 08-29-2010, 07:40 PM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold
Both were high compression engines.
Old 08-29-2010, 08:11 PM
Thanks for info im an old FE guy, i was told i would be at 12.5 to 1 with the dove heads is that about right?
Old 08-30-2010, 04:50 AM
If my memory is correct my 71 Colony park 429 used D0VE heads and was 11.5:1, dad's 70 Mark III was also 11.5:1 on the 460.
Old 08-30-2010, 04:13 PM
Slip ford man's Avatar
Slip ford man Slip ford man is offline
Slip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud of
I think that there were two deck height changes, prior to the D9 block. The first change was in 1970 1/2. I have a 78 dive block, and with the c9ve heads that I'm cleaning up as a winter project. I'm not sure what the ratio will be in the end, but...I'm aiming for pump fuel though
Old 12-26-2010, 04:42 PM
F-4 GUY F-4 GUY is offline
F-4 GUY is starting off with a positive reputation.
The 71 lincoln MKIII came with a 71 block (D1) and 70 heads (D0) with 10.5:1 CR and 365 HP
question about dove heads kaden78ford390 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 11-10-2015 08:48 AM
TYPES OF DOVE HEADS robjs111 1973 - 1979 F-100 & Larger F-Series Trucks 15 04-02-2010 02:28 PM
429 or 460? shadow_almanza 1973 - 1979 F-100 & Larger F-Series Trucks 3 03-01-2010 07:55 PM
Dove-c Boz Turner Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 8 07-27-2009 10:53 AM
flo numbers for dove heads tess100 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 11-04-2004 02:14 AM
Tags
429, 460, block, blocks, c9ve, compression, d0ve, d1ve, d3ve, deck, dive, dove, ford, heads, height
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
