2009 Escape Sun Roof Leaking - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 08-29-2010, 12:34 AM
mikepcola mikepcola is offline
mikepcola is starting off with a positive reputation.
Cool 2009 Escape Sun Roof Leaking
Took my Escape to Ford Dealer to be fixed they had for 3 days. Got it back Thursday & by Friday it was Leaking again. The Gasket was replaced, next the headliner willl be stained. This is not what I expect for a new Ford. Mike Pcola Fl
Old 08-29-2010, 09:30 AM
Buck 1 Buck 1 is offline
Buck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to behold
Before condemning Ford because of a leak, go to a different dealer and have them fix it right. I , and many others, have moon roofs, and no leaks whatsoever. If your dealer had the vehicle for 3 days, and did not repair it correctly, your gripe is with them.
Old 08-29-2010, 08:55 PM
tcesni tcesni is offline
tcesni is starting off with a positive reputation.
Certainly shouldn't leak. Take it back and make sure they do it right, in one day.
Old 09-08-2010, 11:53 AM
Went back to Ford Dealer (World Ford Pensacola) they said it is suppose to leak a small amount ??? Will be my Last moonroof. MIKE L
Old 09-08-2010, 02:26 PM
Bert56's Avatar
Bert56 Bert56 is offline
Bert56 is starting off with a positive reputation.
Quote:
The excuses I hear from some dealers is incredible. So, what do they call a sun roof now, a rain roof?
I also have an Escape and hope it doesn't leak this winter.
Thanks, PK
Old 09-08-2010, 02:49 PM
Torky2 Torky2 is offline
Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.
Dealers... ya gotta lov'em... no we don't!
You need to find a dealership where the service dept people have at least one functioning brain among them. This lack of brains is not limited to any particular make of vehicle.
The shop manual has a Pinpoint Test sequence for diagnosing "Roof Opening Panel Leaks". It runs from making sure the customer is parking with the roof opening panel correctly in the closed position, to checking the alignment of the panel, the weatherstrip condition, the water trough condition, the drain hoses (they run down the A & C pillars), checking the drain hoses for correct flow, and lastly, checking the condition of the roof opening panel frame for damage.
You just need to find a dealership where they will actually do it. Yes, you should NOT have to chase around dealers to get the job done correctly. But alas...
I too did not want a sunroof/moonroof/whatever roof. I like a solid roof that I don't have to worry about a leak, broken glass, dead motor or switches, etc. But my wife is the primary driver of it, and the car is really for her use. After she said that for how long we keep vehicles, that it is possible this might be her last new car, I figured if she really wanted a sunroof, well, I'd go with it. So she picked the color and the sun/sync package and I added the cargo package.
I had a feeling that the sunroof would rarely be used, and so it has.
Ford escape console removal Mgray770 Escape & Escape Hybrid 2 12-18-2014 08:34 PM
2001 Escape rattle in motor and no acceleration? Dwayne1 Escape & Escape Hybrid 3 12-04-2013 12:27 AM
2002 Ford Escape bhelton26 Crossovers 0 08-18-2013 12:25 PM
1.6L Eco Boost Escape/Fusion RECALL BIGKEN Escape & Escape Hybrid 48 12-31-2012 07:33 AM
2001 ford escape headlight with moisture rweiss Escape & Escape Hybrid 7 07-13-2005 01:41 AM
Tags
2005, 2008, 2009, 2010, escape, ford, leak, leaking, leaks, marinar, moon, problem, roof, sun, sunroof
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
