Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2001 escape misfire after rain
Old 09-04-2010, 04:07 AM
jhtobin's Avatar
jhtobin
jhtobin is offline
my 2001 escape misfires only after it rains, any help please
Old 09-04-2010, 10:38 AM
tonyford's Avatar
tonyford
tonyford is offline
Don't know if you can do this yourself or not, but you have a bad coil pack on one of your cylinders.
If you can determine which one it is by using an OBD reader, just swap it out for a new one.
Coil packs run about $90.
You didn't say if you have a 4 cyl. or 6 cyl. engine. makes a difference in getting at the spark plug and coil pack.
I had my mechanic change one about 5 months ago, another one went about 2 months after the first one. So far the other 4 original ones are still okay.
The older the vehicle gets the more likely these coil packs will go and they can go at any time.
Old 09-05-2010, 06:10 AM
jhtobin's Avatar
jhtobin
jhtobin is offline
Thanks, I'll give it a shot. (6 cyl) hope it's in the front
Old 09-07-2010, 11:41 PM
bmuhlbach's Avatar
bmuhlbach
bmuhlbach is offline
if its the rear coil pack I would change the lower intake gaskets along with the upper intake gasket
Dean Ledgerwood
24
01-25-2021 06:49 PM
2001Escape123
05-31-2014 07:22 AM
CSFord
01-05-2008 11:34 AM
CSFord
12-17-2007 08:21 PM
Quick Reply: 2001 escape misfire after rain
