Oil leak through valve cover harness? Update w/pics! - Ford Truck Enthusiasts Forums
Old 08-28-2010, 11:14 PM
plgebbia's Avatar
plgebbia plgebbia is offline
plgebbia has a good reputation on FTE.plgebbia has a good reputation on FTE.
Is it possible to leak oil through the connection on the valve cover gasket?
I have an oil leak that is leaking down the side towards the back of the driver's side head. It is not the HPOP, or the rail plugs, but the top of the head has oil in that little groove between the head and the VC and it seems to be coming out of the front electrical connection. Is that possible?
Thanks,
Old 08-28-2010, 11:22 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Yes sir unplug it and see if there is oil in it
Old 08-28-2010, 11:23 PM
fordpride's Avatar
also see if your VC are tight
Old 08-28-2010, 11:32 PM
plgebbia's Avatar
Thanks for the reply, I forgot to say that I just checked the VC, they are tight. And yes, there is oil in the connection.
Old 08-28-2010, 11:42 PM
95PSDieselP's Avatar
95PSDieselP 95PSDieselP is offline
95PSDieselP is starting off with a positive reputation.
Quote:
get new VC gaskets
Old 08-28-2010, 11:51 PM
fordpride's Avatar
sounds like it's time for new VC's and UVCH's
Old 08-28-2010, 11:52 PM
plgebbia's Avatar
Thanks, I guess I'll get new Valve cover gaskets.
I think I know where I am going to get them, but anyody have any other suggestions?
Old 08-28-2010, 11:55 PM
fordpride's Avatar
IH or Ford i've got the NAPA Dormin name brand and no problems but if you got the cash then IH or Ford
Old 09-01-2010, 09:53 AM
plgebbia's Avatar
Well, I got the VC gasket, harness, and pigtails inthe kit from Napa-$64.50 out the door.
I tore into my truck last night and found one badly burnt pin an another that was burnt a little. So I replaced the VC, both under the cover harnesses, and one pigtail. It runs and starts much better now!
Here are a couple pics of the burnt pins. I'll try to post a pic of the new one in the truck when I get a chance.
Thanks for the help everyone!
Old 09-01-2010, 07:52 PM
fordpride's Avatar
Glad to here it's up and going again
Old 03-26-2013, 07:02 PM
JasonShrout JasonShrout is offline
JasonShrout is starting off with a positive reputation.
I'm currently digging into my 95 7.3L and found oil on all 4 connectors.
Also, a few of the injector connectors were wet past the seal.
And then... One of the harness connector clips broke off when I was doing the .50 mod.
Bad day!
What negative effects will having oil soaked connectors cause?
Testing high pressure oil system, air coming out CCV... LeoJr 1999 - 2003 7.3L Power Stroke Diesel 8 08-17-2016 06:41 AM
leaking oil from exhaust control valve The Blue mule 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-25-2014 09:01 PM
Oil Leak on 7.3 Power Stroke zthayer 1994.5 - 1997 7.3L Power Stroke Diesel 18 08-18-2012 08:35 PM
Mystery fuel leak... or oil? paddler 1994.5 - 1997 7.3L Power Stroke Diesel 7 03-18-2012 11:31 PM
99 5.4L oil leak (Expedition) Thumper23 1997-2006 Expedition & Navigator 3 12-20-2005 07:03 AM
Tags
1997, 60, cover, diesel, f150, ford, harness, leak, leaks, oil, pigtail, plug, power, powerstroke, stroke, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
