1966 Starter Problem - Ford Truck Enthusiasts Forums
Old 08-28-2010, 07:35 PM
banditosmith banditosmith is offline
banditosmith is starting off with a positive reputation.
1966 F100 automatic 352 or 390 tried to replace 3131 starter.Flywheel hit nosecone and about 1/8 inch of starter drive. Is there another starter or do I have wrong flywheel.Thank you in advance I'm just trying to fix my friends truck.
Old 08-29-2010, 12:04 AM
flipklos flipklos is offline
flipklos is gaining momentum as a positive member of FTE.
No flywheel on an automatic. You got a flexplate.
You proboly have the wrong starter. No 390 in 66 Only 352s.
I would take the starter back and make them refund your cash.
Old 08-29-2010, 04:55 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
I believe I read one of Bill's post saying only one starter for the FE. That would be a 3 bolt, most of the others have 2 bolts.
Truck came with a 352, but a 390 surely could have been transplanted, starter is same for both.
Are the bolt holes lining up? Flip may be on to something you may have the wrong starter.
John
Old 08-29-2010, 05:57 AM
Yes the 3 bolts lined up.I'd like to blame starter,but not knowing what motor is or transmission is maybe wrong flexplate.Meaning maybe 352 with 289 flex plate?I can fix it by grinding nose cone and 1/8 inch off starter drive teeth.SO if there is only one 3 bolt starter and only 1 size flexplate I'll try another starter. thank you gentleman for your help.
Old 08-29-2010, 06:27 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by banditosmith View Post
1966 F100 automatic 352 or 390 tried to replace 3131 starter. Flywheel hit nosecone and about 1/8 inch of starter drive.
Welcome to FTE
C3OZ11002C .. Starter - 3 mounting holes (Motorcraft SA628)
Fits all: 1963/71 Passenger Car & 1965/76 F100/350 FE engines (352/360/390/406/410/427/428) with M/T & A/T.
C5AZ6375D .. A/T Flexplate / 184 tooth ring gear / 14 1/2" diameter / (16) 17/64" bolt holes on a 11 13/32" bolt circle.
Fits: 1965/67 F100/350 352 w/MX Cruise-O-Matic // 1968/76 F100/350 360/390 w/C6.
Fits: 1965/67 Galaxie/LTD/Thunderbird 352/390 w/FX & MX Cruise-O-Matic // 1966/71 Galaxie/LTD/Thunderbird/Fairlane/Torino/Comet/Montego/Mustang/Cougar 390 w/C6.
flipklos: I typed "flexplate" to clarify, but there's not one mention in any Ford Car or Truck parts catalog inre to "flexplate." Ford calls them flywheels whether for a M/T or A/T.
Old 08-29-2010, 08:01 AM
Thank you Numberdummy I'll go check this to what I have.Can't thank you enough.
Old 08-29-2010, 12:17 PM
Quote:
Learn somthing new every day.
Old 08-29-2010, 07:20 PM
The answer was the imported remanufactured starters dont fit.Put on used ford starter end of problem.Hope this saves someone from beating their head against a wall.Thanks for the help Guys.
Old 11-21-2013, 10:23 AM
Carmanico Carmanico is offline
Carmanico is starting off with a positive reputation.
No 390 in a 1966 just 352
My 1966 F100 has this VIN #F10YR802876 which when I decode it means it
has a 360 motor. My son gave me the truck and he says the person that
owned it before him said it had a 360. If it was a transplanted motor would the VIN number be changed?
Just curious as everyone says there are no 360 motors in 1966 F100s
Old 11-21-2013, 10:44 AM
TA455HO's Avatar
TA455HO TA455HO is online now
TA455HO is gaining momentum as a positive member of FTE.TA455HO is gaining momentum as a positive member of FTE.
In 1966 the Y would indicate a 352 2V. The 360 was not available from Ford until 1968. If you have a 360 it would have to be a transplant. And, no, your VIN doesn't change if the engine is swapped out.
Ford FE engine - Wikipedia, the free encyclopedia
In 1968 the Y would indicate a 360 2V. You have to be in the right year to have the correct context for decoding.
Old 11-21-2013, 11:12 AM
360 = Y in VIN
Thanks for the info TA
When I look in the LMC truck catalogue under 1961-66 Vehicle Identification
under engine code there is no "Y" so I went over to the 1967-72 and found
a "Y" and with the info from the previous owners I figured that in San Jose,
California someone must have been ahead of time with a 360 and stuck it
in my truck. It has been confusing when ordering parts and not sure where
I am now.
F700 starter/flywheel problems 88F700 Large Truck 2 05-11-2015 03:48 PM
wierd starter noise aerovan Aerostar 13 11-14-2008 11:26 AM
68 ford 300 6cyl starter problem head scratcher brazospete 1967 - 1972 F-100 & Larger F-Series Trucks 2 02-04-2005 02:38 PM
HELP! Wrong starter??? j.foster62 Clutch, Transmission, Differential, Axle & Transfer Case 6 01-06-2004 09:06 PM
starter no engage 56f600 Flathead V8 & Flathead 6 3 11-11-2003 11:14 PM
Tags
184, 1966, 3131, 352, 390, cruiseomatic, flexplate, ford, hard, mustang, problems, replace, starter, thunderbird, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
