DOOR STRIKER HEX BOLT SIZE? - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 08-28-2010, 08:03 PM
nixvet2000's Avatar
nixvet2000 nixvet2000 is offline
nixvet2000 is starting off with a positive reputation.
I am trying to replace my door striker, but need to know the size of the hex wrench. I have tried every one I have and it's either a bit small or a bit too large. Thanks!
Old 08-28-2010, 08:07 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
T-50 Torx. Should be the same as your set belt mountings.
Old 08-28-2010, 10:06 PM
Encho's Avatar
Encho Encho is online now
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
Bah... got beat to an easy one, X2 on what Grey said. It's also the same Torx used on the tensioner pulley (just to say i added something else), btw.
Oh, and NEVER use hex wrenchs on torx applications, only on emergencies (stranded on the road in the middle of nowhere), you'll damage them.
What is the proper way to adjust F150 door latch/striker? 92 Red F150 1987 - 1996 F150 & Larger F-Series Trucks 20 02-10-2015 01:30 PM
Door Catch Adjustable? Sparky83 1999 to 2016 Super Duty 3 10-11-2012 11:34 PM
Door striker ? V10man 1973 - 1979 F-100 & Larger F-Series Trucks 8 10-02-2012 06:33 PM
Removing the Door Latch Strikers (in the door jams) on my 93 Explorer wickware Explorer, Sport Trac, Mountaineer & Aviator 11 02-04-2005 09:30 PM
F150 door rattles when shut roadman 1987 - 1996 F150 & Larger F-Series Trucks 6 11-05-2001 07:48 PM
Tags
1992, 1993, 250, bolt, dimensions, door, f150, ford, replacing, size, stricker, striker, torx, truck, wrench
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
