2004 F150 Passenger electric window - Ford Truck Enthusiasts Forums
Old 08-28-2010, 07:48 PM
briank briank is offline
briank is starting off with a positive reputation.
Passenger power window will go down but not back up. I replaced the motor, it worked for a month and now it will not go up. Ford replaced the motor. Still doing the same thing. I have plugged the motor on the driver side and it works just fine. I am thinking that there is a wiring problem. Does anyone know where I can get a wiring schematic?
Thanks.
Old 08-28-2010, 08:43 PM
V10man's Avatar
V10man V10man is offline
V10man is gaining momentum as a positive member of FTE.V10man is gaining momentum as a positive member of FTE.
Have you checked the switches? Does it do the same thing with both switches? They are known for getting burned/dirty contacts.
Old 08-28-2010, 10:31 PM
Greg B Greg B is offline
Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.
I also would suspect a switch bad. I have the same problem on my 06. The only time it's a problem is when the wife is riding with me and she rolls down the window and it won't go back up. I checked with the parts guy at my dealer and he told me that the passenger side is a little more $ than the driver side.
Old 08-28-2010, 10:48 PM
It ended up being the main power window control (driverside control) switch, it has Corrosion on the contact. We are going to pull it a part and clean the contacts before we spend $70.00 at the dealership for a new one. What I found out is if while pushing it up or down, which ever direction is not working, if you hold it to the left while pushing the button it will work. Thanks for the reply.
Old 08-29-2010, 04:35 PM
V10man's Avatar
Here is a good link on how to do that.
http://www.f150online.com/forums/art...ow-switch.html
Old 08-29-2010, 06:54 PM
Thanks for the link.
Old 09-04-2010, 11:37 AM
yamaha500ml yamaha500ml is offline
yamaha500ml is starting off with a positive reputation.
Thumbs up Thank you
Cleaned the switches and my window works again, thanks for the helpful information!
Old 02-24-2013, 07:52 PM
lindazman lindazman is offline
lindazman is starting off with a positive reputation.
Thanks for the great post, it did the trick!! All four windows are working again.
Old 02-24-2013, 10:35 PM
seventyseven250's Avatar
seventyseven250 seventyseven250 is offline
seventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud of
Just used this info to fix a window switch. Was relatively easy. Only two problems:
1) The plactic tabs are pretty brittle, and they broke when I was prying it apart. Now it's all loose.
2) the little pins inside are worn down. So the dirty contacts are only half the story. I'm doing to go to the junkyard and see if I can find some more of those pins, I have a few bad switches, and if the pins are the only issue, I'll be in business for nearly free.
Old 02-24-2013, 10:40 PM
Ducky F150 Ducky F150 is offline
Ducky F150 is starting off with a positive reputation.
i have a 04 supercrew and the right rear window doest work as well as my power slider whats the chances the motors are bad or the switches
Old 02-25-2013, 07:38 PM
It would be hard to say without checking things out. But the switches have been problematic in this generation of F150. I have yet to need to replace a motor, but I have replaced 2 of the switches in my 06 F150. I cleaned the contacts on my old switches for backup and thru them in the console.
Power window mystery? Dpan63 1968-2013 Full Size Vans 3 04-09-2014 06:42 AM
Passenger side windowwont go up or down andyman91 1987 - 1996 F150 & Larger F-Series Trucks 12 06-22-2013 02:31 PM
Drivers Electric Window not Working kyledallas 1987 - 1996 F150 & Larger F-Series Trucks 19 01-03-2012 05:42 PM
Passenger Power Window will only go down. EdJones 1999 to 2016 Super Duty 6 09-04-2011 10:33 PM
99 F150 power window issue mikren 1997 - 2003 F150 28 08-22-2009 10:39 AM
Tags
2000, 2002, 2004, control, electric, electrice, f150, f350, ford, passenger, passengers, power, problem, truck, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
