2.5" Hitch
Old 08-28-2010, 05:42 PM
GCLL's Avatar
GCLL
GCLL is offline
2.5" Hitch
I can't figure out what Ford was thinking with this 2.5" receiver.
Are there any ball mounts that fit without grinding? Reese makes a 2.5", but I hear people saying they had to grind them down. WTF, 2.5" is 2.5"! Does Ford have an OEM 2.5" that will fit their hitch?
Thanks...
Old 08-28-2010, 07:07 PM
Huntingbigun's Avatar
Huntingbigun
Huntingbigun is offline
Just buy the adapter 20.00 bucks just goggle reece hitch 2.5 everyone has them, I run one no problem
Old 08-28-2010, 09:06 PM
Rickx's Avatar
Rickx
Rickx is offline
Class V
Thanks...
It's a class five hitch. Like the previous post said get an adapter. In my case I needed a step hitch anyway so I got a class five hitch.
Old 08-28-2010, 09:09 PM
White Knight 2011's Avatar
White Knight 2011
White Knight 2011 is offline
I had issues with the adapter I bought at the local RV dealership. Of course the Ford adapter fits just right.
Old 08-28-2010, 09:36 PM
GCLL's Avatar
GCLL
GCLL is offline
So what's the point of having a heavier 2.5" hitch if everyone is just going to use an adapter and use 2" ball mounts?
Old 08-29-2010, 01:13 AM
kper05's Avatar
kper05
kper05 is offline
My guess is a 2" is fine for most owners needs when using bumper pull (ex. utility trailer). Anything heavier will use a gooseneck ball or 5th wheel hitch.
Old 08-29-2010, 03:47 AM
dc3655's Avatar
dc3655
dc3655 is offline
Have you seen the size of some of the toyhaulers and other bumper-pull trailers out on the road? They are so far past the weight ratings of the 2" hitches. It's a good idea to put the heavier duty receivers on these trucks. That being said, most people are used to the 2" receivers and all their hitches go in a 2" receiver, but it is still safer to use the 2.5" system for those who do tow heavy. Don't forget that this is a very powerful diesel truck and people are going to continue to tow heavier and heavier loads with them.
Old 09-30-2010, 11:15 PM
mvedepo's Avatar
mvedepo
mvedepo is offline
Which hitches are these? I took my 2" receiver to the Ford dealer and it fit perfectly in the '11 F-250 there. Was there an option of getting a larger hitch? Can't find it on my window sticker.
Is there a class V option?
Old 10-01-2010, 01:33 AM
cford716's Avatar
cford716
cford716 is offline
Must have been built before they switched to the 2.5" sometime in May if I remember correctly.
Old 10-01-2010, 01:54 AM
Shakedown St.'s Avatar
Shakedown St.
Shakedown St. is offline
I'll have to double check what my trailer shop installed. Def not a Reese but they sold me a receiver that slid right in my class 5. I did not nor should not have to grind anything!
Old 10-01-2010, 08:17 AM
6.7Fan's Avatar
6.7Fan
6.7Fan is offline
I just picked up class V 2.5" from the local State Trailer Supply and it slid right in as well. No issues.
Old 10-01-2010, 08:34 AM
Champ198's Avatar
Champ198
Champ198 is offline
I bought the U-haul 2.5" adapter. On the sku description they call it the Ford adapter. It had to be tapped-in to get it started but it fits fine. I had to add some shims as my 2" hitch had a bunch of movement and slop that I didn't have before. Anyone know where we could get 2.5" hitches that are reasonably priced?
Old 10-01-2010, 09:17 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
yeh, about that 'reasonable' thing..
etrailer.com lists them from $50 to 260..
Sam
Old 10-01-2010, 09:24 AM
djjoshuad's Avatar
djjoshuad
djjoshuad is offline
they're all over the internet for $40-80 depending on quality and drop. Even my local truck parts store carries one for $75 (not including ball). It's not as cheap as a 2", but it's heavier duty... so I guess we knew it would be more expensive.
right now I'm running an adapter with my old 2" ball mount. I need more of a drop on this truck, so this afternoon I'm going to go pick up that $75 one from the truck accessory place
Old 10-01-2010, 10:59 AM
6.7Fan's Avatar
6.7Fan
6.7Fan is offline
Got mine w/ a 7 inch drop at State Trailer Supply. I think the hitch was about $70, got 3 different ***** and a nice locking pin. Out the door was approx $120 (don't have the receipt on me). They had 3", 5" and 7" drop in stock. We measured the 7 inch and it should be perfect with my height (leveling kit and 35" tires).
Quick Reply: 2.5" Hitch
