how to turn off CEL after plugging EGR?
Hey folks, getting tired of my EGR valve plugging up and disabling my Excursion, I pulled the valve and installed an EGR plug. The valve is still plugged in and sitting on the intake.
After a couple of drive cycles the CEL came on for "low EGR flow".... yeah, you don't say.
Anyhow, what's the easiest way to turn this thing off? I don't want to crank up HP with a "tuner", but if that's what it takes. Can I turn off the CEL and retain the factory performance?
Tuning is the only way I know to get rid of it. If you are dead set on keeping factory performance you can get a custom tune to have it turned off. Contact Matt at Gearhead Automotive. If you have an SCT tuner he can help you out, or the SCT may be able to disable it as a stand alone item right out of the box.
I will say I have a 13K tow tune from Matt and I can't stand the lack of power when unhooked. I run the SRL+ when unloaded and it's awesome.
You can get a tune that does nothing to HP levels.
But that is the only option to get rid of the CEL.
You should talk to Matt at Powerstroke Diesel Performance Tuning
He has some that don't up the HP and are very nice to drive.
If you tow with your rig then you can also do a trans tune and that can also
remove the CEL from popping up for the valve. If fact you can stick the
valve back in and it will not open. I pulled mine after about 20K miles
and it was not even dirty. It's been tuned off the whole time.
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
My question is the same as the OP...but I haven't welded my EGR shut yet. That seems the easy/cheap part. Then its several hundreds to get an SCT tuner to turn the CEL off. So, is the mechanics of that, leaving a tuner plugged into the OBD II? (not what I want, as I presently like my ScanGauge). Is the CEL turned off for good, or do you have to turn if off frequently?
Thanks for any further clarity on this.
Also you tune the truck and remove the tuner and put it some place safe.
BTW as I said I have mine turned off that not only turns off any CEL
that it could throw nut it also turns off the EGR valve so nothing goes past it.
Mine has been turned off sense 2013 and every time I have pulled the valve it's
been clean.
One of the things that can be done when the tune is written is the EGR valve
control table is "0" out so that the PCM sees the valve but has no instructions as to when
to open it. So without any table to say open at X it will stay closed. That also helps because
the valve is still in place and active. Just never commanded to open.
Sean
6.0L Tech Folder
been clean.
Sean
6.0L Tech Folder
Yes, certainly will do that. Can you explain why the risk though? It seems my risk should drop considerably from 'stock', and coolant should be a few degrees cooler with loss of exposure to exhaust. I've done the usual flush with Restore, switched to EC-1 coolant, run a coolant filter and have a relatively low mileage motor. My present delta is 9 degrees on the level at 65mph (and that's 'loaded', as by definition, my E-450 RV can't unload). I probably have some oil cooler plugging, but its not pushed me into the danger zone yet, and I hope I've headed that off for a long while.
Silica build-up occurs in the oil cooler.... removing the EGR cooler prevents the reduced coolant flow to the EGR cooler, add heat with reduced coolant and the passages crack. It then ruptures and then allows coolant into the cylinders.... you've possibly prevented that with a plug by removing the exhaust, removing the EGR cooler absolutely prevents that.
You have done nothing for the oil cooler, only prevented EGR cooler ruptures due to excessive temperatures from exhaust gasses, you still need to watch the oil cooler temperatures... for reduced efficiency and rupture. Higher temps than the 10-15* are not as important once the EGR coolers gone, but still an issue to watch once your closer to the efficiency limit of the oil to water transfer limits the cooler affords.
Your risk is reduced, not gone.
Coolant filters remove debris, not silica slime or a chemical reaction between fluids. No substitute for fluid changes and good maintenance practices.
been clean.
Sean
6.0L Tech Folder
been clean.
Sean
6.0L Tech Folder
Thanks! That'll be helpful to pass along to whomever I get to write the tune when the time comes. I understand SCT doesn't actually do that part themselves.
Silica build-up occurs in the oil cooler.... removing the EGR cooler prevents the reduced coolant flow to the EGR cooler, add heat with reduced coolant and the passages crack. It then ruptures and then allows coolant into the cylinders.... you've possibly prevented that with a plug by removing the exhaust, removing the EGR coolerit absolutely prevents that.
Thanks WatsonR, that was very clearly explained. For sure, I'm keeping up with fluid changes etc. Previous owner ran Ford Gold, and I saw some obvious silica gel build-up in my system, as the vehicle unavoidably does run some higher temps on long steep grades and the silica drop-outs would have been promoted then. I'm beginning to keep a log of temperature deltas as was suggested, and if things ever get outta hand I'll be able to see that, and I'll plan for a new oil cooler.
Recovery time would something to watch. If once the load is off (over the hill)
then as the cooling fan is doing it's job you don't see a reasonable drop in heat
I would start looking at the oil cooler. In most cases with a good cooler you should
see a decent recovery time from heavy loads.
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
I used to work swing/graves so I am up all night and take
naps with the cats during the day.
Having that bug really threw me off and I am still recovering.
Also I am sitting here thinking that is the nuts burn Seattle down
because of the new Duck in the house we can start from scratch.
They are just like the sports fans when there team looses.
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
Thanks for the reminder about tracking oil temp recovery after a good climb....I do watch that periodically. That jet engine fan really is a marvel.
Sorry to hear about the Seattle 'unrest'....I'm not that far away (Victoria, BC), but politically we're on another planet, and things are pretty tame up here so far. Maybe we'll see another influx of you'all, which hasn't really happened since the sixties draft dodgers thing (before WE build a wall of course).....sorry, had to lighten things up
