How to keep the lights from coming on when doors are opened?
Does anyone know a way to keep the lights, (interior and running-clearance) lamps from lighting up each time the door is opened? I don't like them automatically coming on, but have found no way to disable this sequence. The old way of just the interior lights coming on with door opening was bad enough, but now all the exterior lamps light up too.
System Programming Instructions - Security/Convenience Function Test
Convenience Functions
All Door Lock / All Door Unlock
Driver door unlock (if installed)
Parking light flash (optional)
Trunk or hatch release
Illuminated entry
Ignition triggered lock/unlock (if enabled)
Illuminated exit
Panic alarm
Memory seat activation (if equipped)
Power side Sliding door activation (if equipped)
Express window down (if equipped)
Headlight illumination (if installed)
Security Functions
Security System arm / disarm
Using PowerCode remote control transmitters
Using factory RKE keyfobs (if equipped)
Verify interior door trim unlock switch DOES NOT disarm system
All entry points trip alarm cycle
Status indicator flashes when armed
Shock sensor settings (lite-touch & full shock)
Remote start convenience functions
Heater & A/C operation during remote start
Rear defroster (if installed)
Remote start safety functions
No remote start activation with the ignition key inserted into the ignition switch (5-chirps)
No remote start activation with the vehicle’s hood open (2-chirps)
No remote start activation with the vehicle’s brake pedal depressed (2-chirps)
No remote start activation with the vehicle’s doors open (3-chirps)
No power window or moonroof (if equipped) operation when remote started (certain models only - see I-sheets).
Refer to the Operators manual as necessary and check out the following functions. If any of the functions below, fail to
operate, first refer to the vehicle specific wiring diagrams and check the wiring and system programming.
Illuminated entry
Illuminated exit
Panic alarm
Security Functions
Sorry to bring up this 'old' thread, but my 2011 F-250 is doing the same thing that the OP describes in his first post. Strangely, I didn't notice the lights staying on when the doors are opened until just last night. I have gone through the manual and cannot find any solution to NOT having the parking lamps and interior lights illuminated each time the doors are opened.
So my questions are these:
1st: is everyone else experiencing their parking lamps and interior lights coming on each time a door is opened on the truck?
2nd: has anyone discovered a way to turn this 'feature' off on these trucks?
I do intend to call the dealer for additional help but would really appreciate hearing from memebers here about what they are experiencing.
1) Yes. They come anytime any of the doors are opened when the truck is not running. I can't remember if they do when it is running, but I think so.
2) No. Tried the dimmer gizmo to no avail.
^^^ Thanks for the reply, Marauder.
I'm wondering if the reason I never noticed the parking lamps coming on each time a door was opened was because the truck was still in 'Dealer Transport Mode'. Now that I have turned that feature off it seems the parking lamps have developed a mind of their own.
Does anyone have any ideas WHY Ford decided that it was necessary for the parking lamps and interior lights to be illuminated for 25 seconds each time a door was opened? I guess I'm not seeing the logic behind this feature...
I can think of 2 situations where it's a good feature:
1) If you are parked on a street at night. This makes the truck much more visible and makes passers by more aware the truck is there, and someone is in or around it. I know I'd swing a little wide just because of the lights.
2) If someone unwanted happens to get your truck door open at night, it draws a lot of attention to the truck quickly....especially with the roof markers.
I don't mind it at all. I think if I had to have the lights come on or not come on 100% of the time, I'd prefer to have them come on. Best case would be user configurable.
GM4WALLS
10-11-2015 05:53 PM
