security from factory?
I did some asking around in this thread- https://www.ford-trucks.com/forums/1...eration-q.html if it helps any it is more background and verification about PATS.
The last post has some additional info on the module. I don't think the cluster is PATS connected. The PATS modules just sends a signal and the cluster displays the info.
As for the odometer- don't know. Did the gauge remain in the truck? I need to take mine out to replace the bulbs so any insight you share is appreciated.
i dont understand how pats is talking to the cluster, anyone have a schematic that shows wires pats is using for the clusteR?
Pats has nothing to do with the cluster except for the warning light. You have the transceiver at the ignition switch which reads the key. Sends the signal to the Pats module which then sends a signal to the PCM to allow starting the truck. There's also one 10A and two 5A fuses for the Pats but other than that nothing else.
I think these clusters are rigged so that you can't just change them out that easily and expect the odometer to work properly. Otherwise, people with high mileage vehicles would just get a cluster with lower miles, replace the old high miles cluster, and sell it as though it has low mileage. Something used car dealerships as well as private sellers would love to be able to do.
From what I recall the mileage is stored in the PCM, not the cluster. Not too sure about the earlier models.
I think thats because the bulb filament forms part of the ground circuit and by removing the bulb you have an open circuit.
now i get a softcode of seatbelt circuit falure or something like that!
#29
#30
<TABLE width="95%"><TBODY><TR><TD>SECTION 418-01: Module Configuration
</TD><TD align=right>2002 F-Super Duty/Excursion Workshop Manual
</TD></TR></TBODY></TABLE>
DIAGNOSIS AND TESTING
<HR>Module Configuration
****** name=tps_proctitle content="Module Configuration">
<TABLE border=1 cellSpacing=0 cellPadding=3 width="50%"><CAPTION>Special Tool(s) </CAPTION><TBODY><TR vAlign=top><TD>[IMG]file:///C:/TSO/tsocache/MEL-PC_7436/S2O~us~en~file=ST2332A.gif~gen~ref.gif[/IMG]</TD><TD vAlign=top>Worldwide Diagnostic System (WDS)
418-F224
New Generation STAR (NGS) Tester
418-F052 or equivalent diagnostic tool </TD></TR></TBODY></TABLE>
Principles of Operation
Some modules must be programmed as part of the repair procedure. If this procedure is not followed the module will not function correctly and may set a number of DTCs, including B2477 or P1639, which indicate that some necessary data has not been programmed into the module.
Modules that need programming should not be exchanged between vehicles. In most cases the parameter values or settings are unique to that vehicle, and if not set correctly will cause concerns or faults.
Some programmable parameters, such as belt minder on/off, can be changed from the factory setting at the customer's request.
WDS will automatically attempt to retrieve the module configuration information from all modules, and from a backup location in the powertrain control module (PCM) when vehicle ID is carried out. If the module and the PCM do not contain correct information the diagnostic tool will either request "As Built" data or display a list of items that you will need to manually configure. The diagnostic tool will program the module based on the data you enter.
There are three different methods that are used for module programming:
- programmable module installation (PMI)
- calibration update
- programmable parameters
Programmable Module Installation (PMI)
The programmable module installation (PMI) method is used when a new programmable module is installed on the vehicle. It is no longer necessary to command the diagnostic tool to gather module option content from the old module. The diagnostic tool automatically obtains any available module option content information from the old module during the vehicle ID routine that runs when the diagnostic tool is initially connected to the vehicle. It is important that you connect WDS to the vehicle and allow it to identify the vehicle and obtain configuration data prior to removing any modules.
Calibration Update
Calibration update is used to install a new calibration and strategy into a module. The updates are usually issued to fix a concern in the module software and would normally be addressed by a technical service bulletin (TSB). This method has been used by the PCM for several years. Other modules will be adopting this strategy as well.
Programmable Parameters
This method is used to configure parameters that can be modified in service. These are typically at the preference of the customer. Not all features controlled by the module are listed in this configuration method. Refer to the Module Configuration Index for a list of features by system.
If a module that has been modified using programmable parameters needs to be installed, the PMI procedure will maintain the parameters in their altered state if WDS is able to communicate with the old module during vehicle ID. Otherwise you may need to use programmable parameters to return them to the altered state.
Vehicle Identification (VID) Block
Some PCMs contain a memory area called a vehicle identification (VID) block. The VID block is used to store backup data for each programmable module, as well as, powertrain configuration information.
If the diagnostic tool cannot retrieve module option content information from the suspect module, the diagnostic tool will attempt to extract backup information from the PCM's VID block.
The PCM VID block contains the factory settings for the configurable modules unless the PCM is flashed with a new calibration, in which case some PCM parameters may be modified.
As-Built Data Center
The As-Built Data Center maintains a record of the vehicle configuration in a database. The vehicle's VIN is required to obtain this information. The As-Built Data Center records the applicable module configurations stored in each module before the vehicle leaves the factory. The As-Built Data Center will always reflect the original build of the vehicle as it left the factory. Only contact the As-Built Data Center when directed to do so by the diagnostic tool.
Inspection and Verification
- Visually inspect for obvious signs of electrical damage. Refer to the following chart:
<TABLE border=1 cellSpacing=0 cellPadding=3><CAPTION>Visual Inspection Chart </CAPTION><TBODY><TR><TH vAlign=bottom align=middle>Electrical </TH></TR><TR><TD vAlign=top align=left>- Wiring harness
- Connectors
The vehicle contains the following modules that are configurable:
- 4- wheel anti-lock brake (4WABS) control module (if equipped)
- vehicle security module
- overhead trip computer (OTC) (if equipped)
- restraint control module (RCM)
- air suspension control module
- 4-wheel drive control module
- instrument cluster
<TABLE border=1 cellSpacing=0 cellPadding=3><CAPTION>Programmable Parameters Index </CAPTION><TBODY><TR><TH vAlign=bottom align=middle>System </TH><TH vAlign=bottom align=middle>Programmable Parameter Items </TH></TR><TR><TD vAlign=top align=middle>Warnings and chimes </TD><TD vAlign=top align=middle>Belt minder </TD></TR><TR><TD vAlign=top align=middle>Tire size and axle ratio </TD><TD vAlign=top align=middle>Tire size </TD></TR><TR><TD vAlign=top align=middle>Security </TD><TD vAlign=top align=middle>Autolock/Relock </TD></TR></TBODY></TABLE>
Configurable Modules — Excursion
- driver seat module (DSM)
