99 F250 rear SC door stuck closed - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-28-2010, 02:42 AM
GregGimbert GregGimbert is offline
GregGimbert is starting off with a positive reputation.
Seems as though the upper rear latch on the little rear door is stuck shut. The door handle only opens the bottom latch, both inside and door jam handles tried. Anyone had this problem. Tried search with no relevant results. Thanks, Greg
Old 08-28-2010, 11:25 AM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Mine has stuck a time or two after off-road body flexing. I found that pushing inward on the door at the top would free it. Pulling out would not free it, but pushing inward while pulling the door handle popped it loose. Once you get it loose a little lube on the latch should fix it.
Old 08-30-2010, 01:52 AM
Tried that, didn't work. Anything or anyone else?
Old 08-30-2010, 11:51 AM
Savoy John Savoy John is offline
Savoy John is starting off with a positive reputation.
I had the problem with the lower latch. Rusted in the closed position. Had to use a pry bar to get it opened.
Old 08-30-2010, 12:08 PM
Fishin76's Avatar
Fishin76 Fishin76 is offline
Fishin76 has a good reputation on FTE.Fishin76 has a good reputation on FTE.
Quote:
YIKES!!! Anything I can do to prevent this?
Old 08-30-2010, 12:16 PM
Keep all the latches well lubed. I used a grease gun with a pinpoint adapter to get the grease well into the pivot points.
Old 08-30-2010, 04:19 PM
BillyBob69's Avatar
BillyBob69 BillyBob69 is offline
BillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to all
Could be the linkage came apart. I have a few threads in here about this. Do a search for rear door and I am sure you will find a thread with the instructions on how to get to the latch mechanism when it is closed. Then you can remove the door panel and trim and get it fixed.
Crew Cab Door Stuck Closed hateme 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 10-17-2015 07:04 PM
Rear door latch, super cab. NEW problem??? pwstroker69 1999 - 2003 7.3L Power Stroke Diesel 14 03-17-2015 09:37 AM
HELP - 07' Rear door latches freezing. fordiesel69 2004 - 2008 F150 1 11-22-2014 06:17 PM
door latch sticking TXCITYDPS 1973 - 1979 F-100 & Larger F-Series Trucks 0 08-16-2011 11:46 AM
1970 Door Latch Stuck FAST-FORD 1967 - 1972 F-100 & Larger F-Series Trucks 3 03-25-2008 08:43 PM
Tags
2003, 250, 99, door, doors, duty, f250, ford, jam, open, rear, sc, stuck, super, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
