I have to choke the carb
What he said. Grab the throttle shaft where the linkage attaches and see how sloppy it is. Chances are your throttle shaft and/or base is worn quite a bit.
I have to give it half choke to start it, then drive it for a couple minutes before pushing choke all the way in. Then it runs perfect.
If the truck has sat for a week or more, I have to pull full choke and pump the gas pedal to get fuel back in the carb bowl. Takes 3 or 4 try's before it starts
Engine was completely overhauled this spring, and all gaskets are new.
Carb was overhauled also. I know the base of the carb and intake surfaces are true and flat.
What you have sounds normal to me as well. I would be happy if mine would start with only a couple of tries at full chock after sitting for a week. All of the fuel seems to drain from the bowl after three or four days - no matter what power valve and gasket combination I have tried. Enjoy the easy starting and no running problems once warm.
bjoern
12-16-2002 05:29 PM
