Calling supercharged EFI 460 owners
As the title states. Looking for EFI 460 owners. I put a used Vortech unit on my 96 last year and i just blew the front oil seal. I have heard that there can be an oil drain issue when the drain goes into the valve cover. That i should go to the timing cover or the pan? Any one else have oil draining issues?
Is your drain having to run uphill? if it's anything like a turbo then it's always nicer to be able to run the drain to the pan, but as long as your drain isn't trying to run uphill or parallel then you should be fine. If you don't want to deal with that and having drain problems then put a pump on it and you shouldn't have drain problems anymore.
Vortech finally called me yesterday. They got to looking at my head unit. And while i had them on the phone i asked them about the oil drain. They said all their new kits drain to the pan due to the old way(into the valve cover) was causing problems. So i think i am going to have it drain straight down into the timing cover. I know this is what 1st gen lightning owners do
I am unsure of the milage as the s/c came from a junk yard
Cool. I just bought two used kits myself. Another member here already has first dibs on the one I'm going to sell after I get one installed. I'm excited.
How much boost are you making? These ones have 2" pulleys on them for my high altitude. Only makes 5psi at 6000ft on stock 460, from what I hear..
Ronnief150man
21
03-16-2016 01:28 PM
carconnoisseur
13
02-01-2016 09:02 AM
Turbo Dog
07-09-2014 07:06 PM
Old Brown F250
09-16-2013 11:36 PM
darkstar8
07-23-2011 05:15 PM
1996, 40, 460, 95, big, block, efi, f350, ford, reviews, sale, supercharged, supercharger, superchargers, vortech
