63 unibody heater control valve
I am looking for a heater control valve that mounts on the inner fender, all the sources that I've been too have the wrong ones, or maybe I have the wrong one! The one I have has three mounting holes in a base shaped like a triangle and then bends up 90 degrees and the valve has an arm for the cable. Is this the right one for a 63? Any help?
Thanks
Robert
Thanks
Robert
Since I just got finished welding all the unused holes in these fender panels I would like to find a direct replacement if possible, any other info on the Mopar piece? I looked at several at the Auto Zone from 57 thru 70 and none were the same or even close. Does anyone know if this is the orginal type for 63?
Thanks
Robert
Thanks
Robert
a63unibody
03-30-2001 07:14 PM
