Manual glow plug switch
Old 08-26-2010, 05:48 PM
mabc926's Avatar
mabc926
mabc926 is offline
So I put on a new glow plug relay today and my glow plug light still won't come on, so I'm guessing my glow plug controller is bad and I don't want to spend the cash for a new one, so how do I hook up a manual glow plug switch?
I have the old style glow plug system.
also is there anyway to wire it up so that my wait to start light still works when I push the button?
Old 08-26-2010, 07:20 PM
oreocreaming's Avatar
oreocreaming
oreocreaming is offline
the wait to start light wont matter if you do a push button cause your bypassing the controller so it will stay on the whole time. all you have to do to make it a push button is run 12v to a switch(button) and run the power out line to one of the small threaded terminals on the solenoid. as soon as you put 12v to it you will hear it click. some say S on the plastic by the post. read this post first.... https://www.ford-trucks.com/forums/9...old-style.html
Old 08-26-2010, 07:36 PM
mabc926's Avatar
mabc926
mabc926 is offline
Ah ok...so all I have to do is fined a 12V source that turns on when the key is at half, run that wire to the switch, and from the switch to the purple wire, and when ever I push the button the wait to start light will stay on til I let go of the button?
so another question, what size wire should I use and does it matter what kind of a switch I get?
Old 08-26-2010, 11:52 PM
oreocreaming
ive got a different glow plug system then you do, my 90 is a totally different setup then you got bud. i dont know if yours will come on or not when you run power to it. but again, the light wont matter since your controlling the glow plugs yourself. without the controller working itself then the light wont do what you want it to.
Old 08-26-2010, 11:58 PM
mabc926's Avatar
mabc926
mabc926 is offline
I know the light won't matter if it's on a manual button.....I just want the light to light up though....no real reason behind it....I just think the light would be cool.
Old 08-27-2010, 12:06 AM
oreocreaming
you can always run the 12v to the solenoid AND to the purple wire that goes into the cab and lights up the light. easy enough eh?
Old 08-27-2010, 12:08 AM
mabc926's Avatar
mabc926
mabc926 is offline
That would work!
Old 08-27-2010, 11:35 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
On the old style system, the wire to the dash light is the third wire (black with pink stripe) on the glow plug terminal of the relay.
So the Wait to Start light will still work.
What kind of switch, momentary switch only, that way it can not be left on or accidently bumped on burning up your glow plugs.
Old 08-28-2010, 12:31 AM
mabc926's Avatar
mabc926
mabc926 is offline
So if I put in a push button do I just unhook the controller and fill in the hole with a pipe plug or do I just leave it plugged in?.....since I would be unhooking the purple wire I guess I could leave it plugged in but I don't know.
Old 08-28-2010, 12:47 AM
Dave Sponaugle
I would leave the controller where it is.
More than on report of the controller twisting off when you try to remove it.
If that happens, you now have a coolant leak.
I switched mine to manual control when the original controller died.
The controller stayed there until the engine was out of the truck.
When I built my current motor, 1/2" pipe plug does a nice job of sealing the hole.
Old 08-28-2010, 12:51 AM
mabc926's Avatar
mabc926
mabc926 is offline
Alright....sounds pretty straight forward now......thanks for all your help Dave!
kent hittle
16
02-11-2016 04:18 PM
tommyl
11-11-2014 11:18 AM
the
08-06-2011 08:59 PM
flainn
25
03-30-2011 11:07 AM
DJOHNSTON78
08-24-2008 04:54 AM
Quick Reply: Manual glow plug switch
