Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 08-26-2010, 02:35 PM
IRONHORSE-T1 IRONHORSE-T1 is offline
Garage is empty, add now
IRONHORSE-T1 is starting off with a positive reputation.
SUN VISOR / KEY PAD CODE
I have had my EL Limited now for about 3 days and i have nearly figured out all the buttons on this thing. But 2 things i cant figure out, on the driver sunvisor, there three little buttons with a what looks like a house symbol, my instincs and common sense tells me its the garage door opener (i think), but i cannot find any reference to it in the manual. Any one have any insight on the "how to's" of this feature?
Also, the infamous key pad code. The dealership said they did not have the code and the card with the code on it was not in the black book in the glove box, so does anyone know were on the vehicle somewhere the code is located? Frame, under dash, kick panel?
  #2 (permalink)
Old 08-26-2010, 03:00 PM
Mud Doc Mud Doc is offline
Mud Doc is starting off with a positive reputation.
sun visor buttons
There are 3 buttons--all will work with most electronic door openers. Your garage opener should have a 'sync' button on the back of it somewhere. For my 450 and Nav, simply hold down the button you want to use and the door opener should indicate it is receiving a signal--then just pust the sync button on the opener and it should work. I use the end buttons on both vehicles for the garage and driveway gate openers. It works very well and you don't have to have an opener hidden away somewhere. By the way, Ford calls it 'HOMELINK' might look for that reference in the owners manual.
As for the keypad codes--if you did not get them with the vehicle, you will need to go to a dealer with the VIN. Some dealers will look it up for free, others will charge.
Joe
__________________
2009 F450 Lariat CC 4x4
2005 Mobile Suites 36TK3
2011 MKX
  #3 (permalink)
Old 08-26-2010, 06:36 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Make the dealer pull the door code. It's not something you should have to pay for. They have to do it.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #4 (permalink)
Old 08-26-2010, 07:09 PM
hjsimpson's Avatar
hjsimpson hjsimpson is offline
2007 Ford Expedition
hjsimpson is starting off with a positive reputation.
When I had my 02 Explorer I think it was located near the fuel reset switch.
Not sure if its the same on the Expy's.
But Berry is correct they should NOT charge you for that.
__________________
2007 Ford Expedition XLT 4X4
Husky Liners Molded Mud Guards ~ Ford OEM Side Window Deflectors ~ WeatherTech Floor Liners & Cargo Liner
Tinted front windows ~ Hunter Bull Bar ~ HIDX 4" HID lights ~ 4" Magnaflow SS rolled angle exhaust tip
Quote:
Never, never, never give up. -Winston Churchill
  #5 (permalink)
Old 08-26-2010, 09:59 PM
Not sure when they stopped putting the keypad codes somewhere under the dash, but on my '07 Nav, it wasn't anywhere. Dealer only place to get it from their computer. My '08 came with the code card.
Joe
__________________
2011 MKX
  #6 (permalink)
Old 08-26-2010, 10:58 PM
st381 st381 is offline
st381 is starting off with a positive reputation.
It's called Homelink and is outlined in the owner's manual how to reset and then program for your garage door openers. If you have two separate doors you can use two of the buttons, if you have rc home lighting you can use the third button. Google the owners manual for the 2007 Ford expy and a pdf should show up somewhere. It's simple to do once you have the instructions in hand.
  #7 (permalink)
Old 08-27-2010, 03:08 PM
Cabinboy07 Cabinboy07 is offline
Cabinboy07 is starting off with a positive reputation.
Homelink is fairly easy to program, but you do need to follow the steps fairly closely. The is a whole step-by-step section in my 07 limited manual, should be the same in yours.
I don't know about the '10, but my '07 came with the code card in the black book.
  #8 (permalink)
Old 08-28-2010, 05:38 PM
gddyup's Avatar
gddyup gddyup is offline
gddyup is gaining momentum as a positive member of FTE.gddyup is gaining momentum as a positive member of FTE.
Ford used to put the default factory key-code on the door-lock/keypad module placed somewhere inside the vehicle. On the old Explorers, it was deep under the seat and you could read the factory code off the side of the module. With the newer models, I'm not sure if they still do that or even where the module is located on our newer Expys. If you had just bought the truck, I would definately head back to the dealer and have your salesperson look up the code for you.
Much easier than trying to take anything apart to find the module.
__________________
Firefighter/EMT IAFF Local 4392
"I've done a fair share of stupid things in my life, a couple of which should have put me in my grave. But here I am typing away as if I had a brain." - Craig Wilson
  #9 (permalink)
Old 08-29-2010, 11:28 AM
berry1234's Avatar
The do not put the code on 07 and up modules.
__________________
  #10 (permalink)
Old 08-29-2010, 06:02 PM
gddyup's Avatar
Quote:
Thanks Berry. I was kinda iffy on that. I figure the dealers want you to come in so they can "diagnose" the code from the "Dealer-Only" programming.....
__________________
  #11 (permalink)
Old 03-31-2011, 10:12 AM
SickPup404 SickPup404 is offline
SickPup404 is starting off with a positive reputation.
FYI - See http://www.ford-trucks.com/forums/87...ntry-code.html.
Tags
2005, 2008, buttons, door, expedition, f350, ford, garage, lariat, lincoln, navigator, opener, program, sun, sunvisor, visor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
