Bad Master Cylinder?????? - Ford Truck Enthusiasts Forums
Old 08-25-2010, 03:54 PM
Bladely's Avatar
Bladely Bladely is offline
Bladely is starting off with a positive reputation.
Question Bad Master Cylinder??????
Ok I have a 1990 F-150. It sits most of the time. The other day I gave it a tune up and when I went to go for a ride, I lost the brakes, then all of a sudden they came back. They were not as strong as I think they used be. So I had my dad take it for a ride and it wouldnt do it for him then all of a sudden he went to slow down for a corner and the peddle went to the floor, hit the peddle again and they were back. So a long story short, is it the master cylinder or something else? Any Ideas?
Thanks
Old 08-25-2010, 04:08 PM
leavy20 leavy20 is offline
leavy20 is starting off with a positive reputation.
first check your fluid level. these trucks do have a valve that will block a blown line (not very well though) also check for fluid leaks. i would suspect a blown line before a master going out.
Old 08-25-2010, 04:10 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is online now
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
Sure sounds like the master cylinder to me.... "Worn out cups/seals"
Old 08-25-2010, 05:53 PM
Ricache's Avatar
Ricache Ricache is offline
Ricache is starting off with a positive reputation.
Relatively easy to replace. Just did mine last month. Bench bleed the new MC before installation. Used a mighty vac at the wheels.
It's really cool to see new DOT3 fluid in the master cylinder reservoir for a change instead of that cola colored crap that was probably in there for 20 years!
Good luck.
Old 08-25-2010, 06:12 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
As long as there is no actual outside fluid leak I vote for the master cylinder. A bad RABS module will usually result in a soft pedal, not a complete drop to the floor.
If you are leaking fluid, start looking for leaking wheel cylinders in the rear or caliper pistons in the front as well as leaks in the lines/hoses leading to them.
Old 08-25-2010, 06:40 PM
Bladely's Avatar
No there is no fluid leaking and all the lines look good, that was one of the first things i checked. Thats why i was thinking master cylinder. Now what is a RABS module, ive never heard of that before?
Old 08-25-2010, 06:56 PM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
RABS = rear anti-lock brake system
Sounds like the master to me as well.
Old 08-25-2010, 08:42 PM
jplinville's Avatar
jplinville jplinville is offline
jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.
I'd check the vacuum line to it for cracks and such...before you start throwing parts at the truck.
Old 08-26-2010, 09:20 AM
rla2005's Avatar
Quote:
Cut from my Ford Service Manual:
Anti-lock brake control module (dual solenoid electro-hydraulic valve) located on the left frame side rail (5015) just behind the No. 1 crossmember.
Left frame implies driver's side of the truck. I just noticed your truck is a 1990. I am not sure when Ford introduced the Rear Anti-Lock Brake system. Yours may have the standard brake proportioning valve instead of RABS.
Old 08-27-2010, 03:00 PM
Bladely's Avatar
Im thinking it does, it has the rear abs light that lights when you start it then goes out.
Hopefull saturday i can tear into it....was planning on it tonight but my job has bigger plans for me.....lucky me! LOL
Help! New rear brakes, peddle goes to the floor intermittent? radmacks Excursion - King of SUVs 6 03-23-2015 08:25 AM
Spongy brakes 88 f250 redrivergorge 1987 - 1996 F150 & Larger F-Series Trucks 6 08-30-2010 09:33 PM
1963 F600 brakes arwford 1961 - 1966 F-100 & Larger F-Series Trucks 11 08-21-2010 05:55 PM
1989 F150 Brakes just went out ChurchBuilder 1987 - 1996 F150 & Larger F-Series Trucks 10 05-20-2007 10:03 PM
soft brakes in heat? nhswrld 1973 - 1979 F-100 & Larger F-Series Trucks 11 06-24-2005 12:31 PM
Tags
1994, 1996, 250, 86, 93, bad, blake, blessed, cylinder, electrohydraulic, f150, ford, master, ranger, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
