t170 trans to flathead?
I am looking for a way to use a 4 speed in my 53 v8 flathead to give me some better gearing with a new 9" I am dropping in. Finding a 4 speed that is of the smae year have proven to be hard I was wondering how about using a t170? Has anyone done it and is there much involved?
FWIW the gearing on these isn't great. 2nd to 3rd is a big gap. Depending on your gears and tires, it will either be a nuisance or a real pita.
If I was doing all the work, I'd go T5. The 4 speed ODs aren't strong transmissions, so anything they take, a T5 will take. Especially the aluminum case units.
jmo, good luck with it.
First off if you plan on using anything other than the stock tranny your going to have to modify the tranny crossmember. If you want to stay with ford parts then in the family of the T98 is the T-19 with all forward syncro gears and come both wide and close ratio gears. The close ratio gear set has the same gearing as the T-5 minus the overdrive 5th. I've seen t-19's on craigs list for $100 bucks. You don't say were you live but I don't think your going to be happy with that 3.00 gearing unless your living at sea level and no hills. I'm running 3.50 and wish I had gone with 3.70. I may correct that this winter. In my build I re-used all the stock pedels assemblies and clutch parts.
raven3
04-30-2020 05:30 PM
DAD'S51
10-13-2016 08:05 PM
farmall_7
10-15-2015 06:22 PM
mstng5point0
10-20-2012 02:38 PM
