'97 F150 tailgate handle broken - Ford Truck Enthusiasts Forums
Old 08-24-2010, 11:05 PM
LBF's Avatar
LBF LBF is offline
LBF is gaining momentum as a positive member of FTE.
After I had Line-X sprayed in the bed of my '97 F150 the tailgate became difficult to open, and eventually the latch broke. What is involved in obtaining access to the internal workings of the handle?
Old 08-25-2010, 12:45 AM
phil6608's Avatar
phil6608 phil6608 is offline
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
Put down the tailgate, remove screws on plate in center. After that there should be 2 or 4 screws in there that hold the handle on. Remove them and you can take it right out and fix or replace.
Old 08-25-2010, 10:26 AM
redwood's Avatar
redwood redwood is offline
redwood is gaining momentum as a positive member of FTE.
Quote:
What he said. While you're in there, lube all the contact points so you won't have to do it again in the near future.....
Old 08-25-2010, 03:48 PM
LBF's Avatar
LBF LBF is offline
put down the tailgate...
You see, that's the problem... The tailgate won't open. You pull up on the latch and nothing happens.
Old 08-25-2010, 04:03 PM
phil6608's Avatar
Get in the bed of the truck and work on it there!
After you get the plate off,,,,,you can reach inside the hole and open the gate.
Old 08-26-2010, 12:29 AM
Nightmare97 Nightmare97 is offline
Nightmare97 is starting off with a positive reputation.
Quote:
No, I don't see. Your header says you have a broken handle, not a broken latch, but then you go on and on about a latch as if they're one in the same in your post. So what exactly is broken, the handle, or a latch.
Old 08-26-2010, 03:38 AM
LBF's Avatar
LBF LBF is offline
Sorry, Sorry - so Sorry!
Quote:
Didn't intend to cause confusion. To all appearances, the handle that you lift up on, the one that normally causes the truck tailgate to transition from the verticle, secured position to the horizontal, unlocked position - is entirely intact and completely functional. However, the latch mechanism, the part that is somehow mysteriously manipulated by the previously mentioned manipulations of the also previously mentioned handle, is apparently no longer capable of being manipulated by any manipulation of the handle.
There, is that better?
Old 08-26-2010, 04:01 AM
Much! So here's the hot ticket, anything can be manipulated with a big F-ing Hammer!
Old 08-26-2010, 04:18 AM
O.K. It sounds like you're already inside the tailgate and tried to un-latch the latch at the latch itself and it still won't pop. Without tearing my tailgate apart, from looking at the outside, I'd say you're a little screwed. This is what I would do if there's no way the latch is going to pop. Unscrew the pin (it has a torx bit head) that the latch is holding from the inside of the tailgate, then you can remove the latch with the pin. Sounds simple in theory, good luck to you Bro.
Old 08-26-2010, 10:45 AM
redwood's Avatar
From inside the truck bed, after you remove the long cover that runs the width of the top of the tailgate (not the plastic cap, but the service cover for the gate) (and you may have to get a razor blade after it if they didn't remove it when they sprayed your liner) you will see a bar on each side running from the center of the gate to the side latches. Pull those bars toward the center to open the gate. If it started this AFTER the liner was installed, I'll bet they removed the cover to spray the gate (the right thing to do) but didn't tape off the opening properly (the wrong thing to do) and you got some liner funk in the handle mechanism causing binding. Once you get the gate down, and the cover off, if you can't find the problem visually, take the mechanism out and clean/lube it real good and you should be good to go.
Also check the latches/strikers at the ends of the gate. You could have some liner overspray there that's binding it up.....
Tailgate Step Handle 1984_355w WTB - Parts & other 0 02-05-2015 12:05 PM
re-keying tailgate TexasA&M 1999 to 2016 Super Duty 3 12-11-2013 11:38 PM
94 tailgate handle what other years will work. crashed13 1987 - 1996 F150 & Larger F-Series Trucks 3 05-11-2011 05:00 PM
Tail gate handle pintoches 1987 - 1996 F150 & Larger F-Series Trucks 6 10-08-2010 11:05 AM
painted door handles stroken 1999 to 2016 Super Duty 31 11-15-2007 06:43 PM
Tags
94, broken, f150, fix, food, handle, latch, lift, open, pin, replace, rusted, tailgate, talgate, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
