1954 Panel in the weeds...Really
I bought this Buick last year for $550. It looked pretty decent and complete. It wasn't actually sitting on the ground, there was about 3" of clearance. I ended up only saving the front clip, which I was told by a Buick expert is worth around $1000 in parts so I don't feel too bad about the initial cost. I also was able to use the door mechanisms and some trim pieces. I ended up cutting up the rest and scrapping it.
Your Buick expert must be interested in buying those parts pretty badly considering the low buck estimate he gave you of what the parts are worth.
The side mount fenders are highly desirable (worth faaaar more than a grand each), even if beat up, rusty and more so...if the covers are present.
If the grille is straight, it's worth another grand EZ. Those delicate horizontal bars broke if you looked at them.
What happened to the Straight 8? Did you save any of the dash gauges or the outside door handle/mechanisms that are not afflicted with the usual GM dropsical condition?
Looks like a 1937 Series 80 (Roadmasher) or 90 (Limited).
I ended up buying another Buick, a Limited, basically a limousine, for $150, salvaging all the usable parts to trade to the Buick guy for 4 nice doors, trim pieces, recored radiator, headlight buckets and other parts I figure are worth at least $1000. When he saw my rust bucket body he sold me a solid frame and body for $100. With all the wheeling and dealing I haven't really stuck too much into this beast, yet.
If you say so, but this Buick appears to be on the long 131" wheelbase used by Series 80/90's.
Special's were on the 122" wheelbase.
These are great cars, highly collected, and dependable with their OHV Fireball straight 8.
I had a 1941 Century coupe with the dual carb option. Paid 40 bucks for it in 1964 and drove it home.
Received 4,118 Likes
on
#30
I bought a set of boards from www.smoothiefabrications.com for my panel. They are made from 16 gauge and are smooth /no ribs. I had to make and weld attachment brackets to the bottom to mount them to the frame brackets because I didn't want bolts showing through the top of the boards, I also will be welding an extra support under the area where you step when getting in the cab. www.midfifty.com also sells the same plus fiberglass ones for the 53-56 panels
