Break in oil in new engine? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-24-2010, 08:32 PM
DeereTech05's Avatar
DeereTech05 DeereTech05 is offline
DeereTech05 is starting off with a positive reputation.
As some of you may have read before, I am rebuilding the engine in my truck. Getting close these days if I could get off work at a half way normal hour I could get a lot more done....
My question is do I need to put break in oil in my engine for a while before putting in regualr oil? We always run break in oil for 100 hours in new or rebuilt engines that we build, but I have never heard anybody on here talk about it. What do you guys run on a new engine? I know the factory breaks in the engines when they are brand new so we dont have to worry about that, but in my case its going to be up to me to do it.
Thanks for any input guys!
Old 08-24-2010, 09:28 PM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
rbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to behold
I have in the last 30 years used the normal oil to break in.I do however change oil & filter at about 1000 miles
Old 08-24-2010, 09:35 PM
dn29626's Avatar
dn29626 dn29626 is offline
dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.
Ford was using Motorcraft 10w30 diesel oil in our engines at the factory. I even ordered it through the dealership until i got to 50K miles then went to 15w40.
Old 08-25-2010, 07:21 AM
Quote:
By normal oil you mean 15w-40 and just run it 1000 miles?
Old 08-25-2010, 11:20 AM
SuperDoodie's Avatar
SuperDoodie SuperDoodie is offline
SuperDoodie has a very good reputation on FTE.SuperDoodie has a very good reputation on FTE.SuperDoodie has a very good reputation on FTE.
Just run something like Delo 400 for the first few oil changes.
On my engine, I put in Delo and drove it about 50 miles and then changed the oil. This is due to so many particles and debris from machining that never get cleaned out. Then I went 500 miles and changed it, then 1500 and changed again. After that, went to normal intervals..
Old 08-25-2010, 11:33 AM
itsjustdan26 itsjustdan26 is offline
itsjustdan26 is gaining momentum as a positive member of FTE.itsjustdan26 is gaining momentum as a positive member of FTE.
You should run something with a high zinc additive in it......IIRC Rotella has the highest level. But again I could be wrong...Im not a diesel tech. Im a parts jockey. Someone will be in shortly to help ya out.
Old 08-25-2010, 01:35 PM
We have a break in oil that we run in our engines, they are off road diesels, dont know how much differance that makes other than they get subject to a lot more abuse (dust, long idle times, a lot of lugging). Im just extra cautious on this one since Im footing the bill. Plus Im not used to HEUI system as oil doest have much play on our injectors in Deere engines.
Old 08-25-2010, 01:46 PM
150ford 150ford is offline
150ford is gaining momentum as a positive member of FTE.150ford is gaining momentum as a positive member of FTE.
Are you doing the rebuild your self just curious? What kind off cost is involved. I think I would use 10w 30 diesel oil for the initial break in. Tolerances are tight so quick lubrication is critical. A thinner oil will serve the purpose. 50 or 100 miles change it an then maybe after 500 more miles change it again. Then you should be set to go normal intervals. I use Archer oil. Its an aircraft grade oil that is very high quality. Its not advertised much but its excellent lubrication. How many miles on the original motor? Sorry for all the questions. Just very curious. Good Luck
Old 08-25-2010, 02:25 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
Just run the 15w-40 in it. If you want to add some zinc to it then they have additives for break in that you can put in there to get more zinc in there. Don't start the engine until your ready to drive it either. You don't want it to sit at idle for very long during the initial break in. You want to go drive it on the first start if you can and drive on backroads where your speeding up and slowing down. Get into it a little(not WOT, just about half throttle) to put more pressure against the rings to seat them and repeat it a few times. don't do any freeway driving where your staying at one certain RPM for extended periods. You want the engine to see all RPM ranges during break in. Once you have driven it about 25-50 miles, change the oil. At this point the rings should be seated so just do another oil change around 500 miles and 1000 miles like said above.
Old 08-25-2010, 05:37 PM
Quote:
No problem on all the questions. I am building it myself. I have about $520 in machine work (heads gone through, block bored to .040, sleeve in #5 cylinder, polished crank, mic'd cam, and I think he drilled out some broken bolts), $1780 in overhaul parts, $1095 for 8 injectors, $550 for PHP Pheonix chip, $100 for a new used turbo.......... Im sure there are a bunch of little expenses like paint, sealants, whatnot.
I bought the truck with 236,000 miles on it, everything appears to be orriginal, the air box was broke so they dusted the engine.
Old 08-25-2010, 09:37 PM
dn29626's Avatar
Quote:
Originally Posted by DeereTech05 View Post
...the factory breaks in the engines when they are brand new so we dont have to worry about that...
I just reread your post. I have never heard that before and i do not believe it.
Old 08-26-2010, 08:02 AM
Quote:
Welllllll......... now that you say that you are possibly correct. I know when I had the 6.4 that is what they said, but you know how that goes........
However, I am ready to have this one running, forget the 6.4 and dealing with our ignorant stealership. This engine is gonna make me wish Id done this a long time ago I hope
Z-Max FORDMANMATT 1973 - 1979 F-100 & Larger F-Series Trucks 7 02-20-2014 01:48 PM
synthetic oil problem 68cabby 1967 - 1972 F-100 & Larger F-Series Trucks 9 05-31-2013 02:08 AM
Breaking in a new engine RIKIL 1987 - 1996 F150 & Larger F-Series Trucks 15 08-22-2011 07:09 PM
Question on marine oil change MRKnight General Automotive Discussion 4 04-28-2005 06:28 PM
Synthetic transmission fluid. Break in for Syntetic oil? ebduda Oil & Lubrication 12 11-01-2002 01:19 PM
Tags
10w30, 73, break, breakin, casserly, engine, ford, motor, oil, powerstroke, rebuilt, shots, single, srage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
