95 F250 Won't Start/Electrical Storm!
Wow, last thursday took truck into town ran great, put here to bed. Thursday Night had a hell of a Electrical storm! Friday rolled around, tried to start the PSD and here's what I noticed. #1) "wait to start" light did NOT come on. #2) check engine light IS on. plenty of battery to easely turn vehicle over but WILL NOT FIRE!...went to O Reilly's and grabbed a code-catcher and unfortunetly, could not get it to display codes. So I went to the book and checked ALL fuses, their good. Checked voltage at the solid state relays - I think they are for the glow plugs, got 12 volts...so researched the Diesel Society on 7.3 PSD and I went ahead and changed out the "Cam Position Sensor" but no luck in firing up.....So I am looking for some advice/direction..Please? This is my first diesel project and she has run strong until Friday...FYI, no mod's performed other than 6637 and a very recent oil/filter change out to Rotella 15/40....thoughts?
x2 .. above ...
Re-check fuse #22 in the engine compartment. It powers the PCM and the fuel filter heater. If the fuel filter heater shorted out then you will get a NO "wait-to-start" light. If that's the case unplug the heater, second connection from top .. drivers side .. on the filter canister. Replace the fuse and retry.
#22 maxi fuse, checks good, Tach has a "slight" bump when trying to start/turning over...running out of daylite, but will check HPOP res. and top off if needed....That Rotella 15/40 does seem kinda thin, only 200 miles on her since the oil change. Will get girl friend to "turn over" truck while I watch fro smoke. Appreciate the help and suggestions from all, keep them coming, as this seems to be electrical..? but hey, I love a good troubleshooting challenge....
A big "Thank You" to everyone, Question, tried the O'Rielly's Code scanner, but it didn't work...wouldn't think NAPA or Autozone would be different?...Is there any Kansas City members who own one? Would compensate for their time and effort to catch codes, Warrensburg is 50 miles down Hwy 50. Very last thing I want to do is have it towed to the Ford Dealer...is there a "name Brand" code scanner that works, I travel to KC on a regular basis and could try to find and "rent" one...
More intel for you guys: 1 year ago, had fluid in the valley of Death, replaced all hoses, repaired fuel bowl with JB weld where pitting occured, replaced bowl heater, water sensors, everything new that could leak from the bowl, Banjo Nut was alittle loose, so I tightened it, and seemed to stop leak. HPOP res. gasket/RTV was leaking, replaced the rubber gasket (OEM) and RTV (OEM) and no leaks...Serviced the HPOP with recommended 1 quart of Oil. Checked the res. last night, I would estimate oil level to be 3/4 full to the plug...Question, if you fill to the top, would it not dump/overflow to the engine and basically "over fill" the engine sump?
Last edited by mq1shooter; 08-25-2010 at 07:40 AM. Reason: ..." HPOP NO Leaks"...since repaired....:)
Put your batteries on a charger after all these starting attempts. And don't waste the voltage trying to crank. If the WTS light does not come on, the truck won't start.
