95 F250 Won't Start/Electrical Storm!
#31
I am cyber challenged but I googled a link to a pic:
This is a pic of the PCM in place. http://image.dieselpowermag.com/f/18...ssions+pcm.jpg
I am sure others have better pics
Also want to throw this out there...I sprayed a little Ether and she fired on that just a little...don't know if that helps or hinders the troubleshooting ideas?...just threw it out there...
#32
ETHER! I have done it before and so has probably 99% of the members on here have but if I don't say it, then it is as good as saying that it is OK. So Don't use ether!
With that out of the way, I used ether when the CPS went out AND when the IDM went out. Both times it kinda fired but I could tell it didn't sound right. I think just the compression of the ether made it combust (maybe someone else could explain). I would still focus on the harness and connection there under the hood. Next I would find a scanner that worked and jot down the codes for us to help you troubleshoot.
#33
#34
#35
Actually CD,, it won't be the IDM or CPS.. PCM is where I would start
No WTS & CEL points to PCM , unless there is a chip you are unaware of (loose) ..
#36
I remember seeing a bad/faulty PCM connection on here under the hood once, it was a ripped boot or something that allowed moister and debris in and interfered with the contacts/continuity. I hope that is what the problem is here.
#37
AHHH! It was just a matter of time!!! (I was gonna bring it up the other day but decided not to). (Long story mq1 [AF predator]).
#39
No easy task for sure! I hope it goes back easily. If the PCM is bad just remember that there are 2 different types. There is the "Cali" model and then there is a "49 state" or FED model. Make sure you know what type of PCM you have/need before buying. (Let me know if you are not sure and we'll figure out what you have).
#40
F5TF-12A650-BJF DPC-202 TEE5 is the numbers on the PCM...original date code of 02/06/95....but ya know, I am having fun digging into it, cause I get to dust off 15 years of dirt and change out dash lights, etc. Found the OEM keyless entry unit, just need to find a replacement keypad? to see if it works.
#41
I am not sure about the keyless entry doohickey. I can't tell by the number if it is a "Cali" or not. I believe the "Cali" models have a "Cali" emissions sticker under the hood, on the hood. Also, at the fuel pump the is a 3"? "UFO" disc that sticks out from under the turbo pedestal. Do you know what you have?
#42
#43
#44
#45
