98 Expedition w/ 4.6L - Ford Truck Enthusiasts Forums
Old 08-24-2010, 06:39 PM
hodges710's Avatar
hodges710 hodges710 is offline
hodges710 is starting off with a positive reputation.
I have this sound from the engine when going up a hill, getting on it hard or pretty much the whole time while above 60 MPH. It sound like an octane knock, just not sure if anyone else has had the issue and was something different. I have checked the MAF and cleaned it, checked the gap on the plugs and now have no clue on what to do to fix it.
Old 08-24-2010, 09:14 PM
hodges710's Avatar
27 views and no one can say something about the issue.
Old 08-25-2010, 02:16 PM
fordinlinesix's Avatar
fordinlinesix fordinlinesix is offline
fordinlinesix is starting off with a positive reputation.
Have you tried a different brand of gas or higher octane? Just trying to rule that out of the equation.
Old 08-27-2010, 10:09 AM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
I think you have diagnosed the problem correctly as spark knock. Try a different brand or octane rated fuel, you could also add some octane booster to you fuel and see if it helps.
You could also have a bad knock sensor and if that's the case it is not telling the PCM to back the timing off a bit. Don't you just love these electronic marvels?
Old 08-27-2010, 03:22 PM
hodges710's Avatar
Thanks for the replies, Ill try a higher octane to see what happens. For my plugs, I have pulled them out to inspect them, nothing seems wrong atleast by looks.
Help winding sound at 1500 rpm tykateexcursion Expedition & Navigator 5 11-27-2012 11:02 PM
1999 F150 Wimpy Horn Sound 162bruins 1997 - 2003 F150 1 08-09-2011 04:01 PM
"Tone" when on Rough Road jasonodsky Excursion - King of SUVs 1 04-27-2011 01:36 PM
Sounds like its knockingHELP katbird704 1994.5 - 1997 7.3L Power Stroke Diesel 22 04-11-2007 07:28 PM
Knocking/Thud Sound in Front End. MSM0075 1987 - 1996 F150 & Larger F-Series Trucks 6 12-27-2004 05:30 PM
Tags
1998, 46, 46l, 98, bad, expedition, expedtion, ford, gap, knock, pcm, plugs, sensor, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
