Right Front Lens Cover Removal on 97 F-350
Just found that the front right turn signal is not working so I guess the bulb gave up after 13 years. After removing the two screws on the top of the lens cover I am still unable to remove it. What is the secret? Are there other hidden screws on the bottom?
pbgsho2
pbgsho2
You're in for a treat then. The only way I know of to get at it unless you have infant hands is to pull the whole assembly. For that you can thank Ford for another rediculously difficult process. Probaly easiest to pull battery out. Then the back side of the light housing there are two I believe but one for sure, 12 mm bolts or nuts. I could only access the bottom one with a 1/4" drive deep socket and had to find it blindly. I can't remember if you have to pull the long headlamp adjustment screws or not but if so they are like 4 or 5 mm. Hopefully someone will chime in with an easier process that I was too ignorant to see but that's what I did.
pbgsho2
04-07-2011 03:02 PM
pbgsho2
11-27-2010 07:33 AM
pbgsho2
07-16-2010 11:06 AM
pbgsho2
16
01-29-2010 01:47 PM
pbgsho2
02-02-2009 10:44 PM
