Turbo Problem
Turbo Problem
Hi everyone. This last weekend my wife and I purchased a 33 ft. 5 th wheel. We had to go to NY to pick it up. Everything was good but on the way home we had a problem. The black plastic hose blew off the turbo. It put a dent in the hood and what a noise. I had very little power and we were in a very bad place when it happened. My wife's cell phone went dead and I left mine home with my wallet. A man stopped and asked if we needed help. That was a very good feeling to see there are people out there that still care.
I put the hose back on. I had to use a piece of my floor mat to pack the clamp out. The clamp bottomed out before it was good and tight.
When we got on the way everything worked. This truck was very very nice to pull the trailer. Good power and very good MPG. I do not know why this happened or if there is something else wrong. That scared the %^%^ out of us. If there would have been a Chevy dealer near the Ford would have been gone.
The clamp bottomed out before it got tight after the first time it blew off. There was oil in the black plastic tube. I cut my floor mat and put it on the outside of the tube so I could tighten it up. The hood has a dent in it and had me rattled for a while. I am looking for an aftermarket part to improve on Fords system.
I was pulling up a steep grade and my boost gauge read between 35 - 40 then it blew. I called the dealer and they were no help at all. I am going to put some black VRT inside the pipe lit it dry overnight then put it on with a new clamp and see what that will do. I can not find any aftermarket part to replace the stock one.
on
I would have to disagree about the clamps and the amount of boost. From my understanding the stock clamps should hold more then what you guys are saying. To me that sounds like a bad clamp in general. I have taken stock 6.0s and hammered them and gotten 35 on the boost gauges. On our 450 at work I can get 40 easy from a standstill when I need to be trucking down the runway but then again its an 09.
I have on tuner and it is stock. I can run the thing up to the red on the gauge when pulling. Empty it will go to about 25 and that is it. I have not replaced the clamp it has stretched and I packed it out with a piece of my floor mat. There has been no change it running it now I just do not trust it at all and if it blows off again I will have to get rid of it. My Ford Dealer was not a bit of help at all. This turned me off of any dealer. I work of s John Deere Dealer and if I talked to people like that I would be fired.
Sam I dont know how far away you are from Newark DE but Porter Ford is top notch. Susan used to go to Ramsey in Elkton but she went to Porter this time. All the stuff Ramsey said needed to be fixed was just fine. I have to get a blow plug fixed but I think the rest of the plugs will be done at Porter. Check them out.
