12 volt power point - Ford Truck Enthusiasts Forums
12 volt power point
Old 08-23-2010, 07:45 PM
skylinekw's Avatar
skylinekw skylinekw is offline
skylinekw is starting off with a positive reputation.
12 volt power point
Did anybody else see the 12 volt power point under the rear seat on the crew cab?
Old 08-23-2010, 07:52 PM
Rafiki2cu Rafiki2cu is offline
Rafiki2cu is starting off with a positive reputation.
No, never new I had one there.
Old 08-23-2010, 08:04 PM
my996duc1's Avatar
my996duc1 my996duc1 is offline
my996duc1 is gaining momentum as a positive member of FTE.my996duc1 is gaining momentum as a positive member of FTE.
yeah, and also inside the center console... kinda nice if you want to leave something charging but don't want to advertise what you are leaving in your car for someone to steal.
Old 08-23-2010, 08:43 PM
FORDTUF1's Avatar
FORDTUF1 FORDTUF1 is offline
FORDTUF1 is gaining momentum as a positive member of FTE.
Yeah, saw that and a bunch more. Here's the only thing I didn't know before buying; the center console with 4 cup holders and A/C, after you lift out the two sections with 2 holders each, there is another flat panel to lift out and there is a canyon of a pocket in there with two molds that can hold the gigantic liter size cups.
Old 08-23-2010, 08:47 PM
BTyner41 BTyner41 is offline
BTyner41 is starting off with a positive reputation.
SWEEEEET!
Old 08-23-2010, 09:28 PM
ruschejj's Avatar
ruschejj ruschejj is offline
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
Yeah, power points are awesome. The inverter charges my Makita Li-ion batts too. Did not know about the hidden cup holders, very cool. How about the weather radar on the Nav screen? Crazy cool...
Old 08-23-2010, 11:51 PM
EpicCowlick's Avatar
EpicCowlick EpicCowlick is online now
EpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud of
This is hilarious. Just like my first 3 hours in the truck. Every other word was, "Cool!" or "Sweet!", or "Awesome!".
Old 08-24-2010, 04:58 AM
skylinekw's Avatar
Quote:
I Haven't seen the weather radar yet, I'll have to look for it today.
Old 08-24-2010, 10:45 AM
skylinekw's Avatar
How do you pull up the weather radar on the screen?
Old 08-24-2010, 02:11 PM
ruschejj's Avatar
Hit the "i" button. Then your menu will have first: "Where am I" and this is what comes up automatically. On the left of the screen you will see a button called "sirius travel link". When you press that on the touch screen down and to the right you will see a button called "weather"
I assume you have the Nav screen and that Sirius is activated in your truck.
Old 01-25-2013, 10:34 AM
throwdown's Avatar
throwdown throwdown is offline
throwdown is gaining momentum as a positive member of FTE.
I tried this and got a interrupt that says I don't have an active sirius account....untrue. I called sirius and they assured me that I do have a functioning account (I'm listening to the radio), and that it has to be enabled by the dealer.
Called the dealer I usually go to and he blamed another dealer who did a PCM flash and said that to fix it would not be covered by warranty. I called the other dealer and they had never heard of Travel Links or weather maps.
I am waiting to hear from them both as they look into it.
Not very encouraging to say the least
Old 01-25-2013, 03:58 PM
ruschejj's Avatar
Sirius travel link is an additional service plan.
You have music, news.
Then you can add travel link
Another add on is traffic.
So, there are three subscription levels, the last two require the nav unit. I think the weather option is $5/month US. Worth every penny for the way I use my truck.
Old 01-25-2013, 05:44 PM
throwdown's Avatar
Everything is included in my plan.........BUT..........I found out that it is not offered in Canada. If they were able to release it I would be able to get it.
My truck is a US truck and has the function in the Nav unit, but nothing falls from the sky. They said maybe by October this year.
Thanks for the reply though.
Old 01-25-2013, 05:47 PM
ruschejj's Avatar
Roger that. I had no idea it wasn't offered up there. Good luck.
Old 01-25-2013, 05:49 PM
messinma messinma is offline
messinma is starting off with a positive reputation.
I did find that one and since it is always hot use it for my solar charger. Mounted to rear glass with Velcro behind drivers side passenger head rest. Sure helps with the vampire drain when I leave the truck parked for long offshore jobs.
Alternator with a weak charge. Freshly Painted and powder coated motors beware scotttahoe 1999 - 2003 7.3L Power Stroke Diesel 12 12-10-2015 11:36 AM
key on power for gauges? sudsmcduff 1999 - 2003 7.3L Power Stroke Diesel 10 02-15-2015 08:00 PM
headlight power volts excavator 1994.5 - 1997 7.3L Power Stroke Diesel 4 11-08-2014 07:11 AM
No power to auxiliary power ports Dmoe512 6.7L Power Stroke Diesel 8 06-29-2014 11:23 AM
12 Volt Accy Power Point ratucker3 2009 - 2014 F150 1 04-12-2011 09:47 PM
Tags
12, 2007, 2011, console, diesel, f250, ford, inter, live, makit, point, power, radar, truck, twelve, volt, volts, weather
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
