12 volt power point - Page 2 - Ford Truck Enthusiasts Forums
12 volt power point
Old 01-25-2013, 09:52 PM
madsonp's Avatar
madsonp madsonp is offline
madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.
That's one thing that really amazed me about these trucks is all the power ports, they're all over the place.
Old 05-03-2014, 07:34 PM
Shiffy Shiffy is offline
Shiffy is starting off with a positive reputation.
Rear under seat power point
anyone know where/what number the fuse is for the power point in the rear seat storage?
Old 06-10-2014, 12:41 AM
Where oh where
Anyone know where the fuse is for that PowerPoint under the rear seat in the crew cab 2013 f350????
Old 06-10-2014, 07:20 AM
720Deere's Avatar
720Deere 720Deere is offline
720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future
It's clearly listed in the owner's manual.
Old 06-10-2014, 07:24 AM
Con"fused"
Quote:
Well, clearly I'm a ******* and can't read. I'm simply asking if anyone knows. There's 2 fuse boxes in 2 separate locations. I checked the fuses for the power points listed but only found the front ones
Old 06-10-2014, 07:40 AM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
Quote:
from 2012 owners guide, here http://www.motorcraftservice.com/vdi...il/default.asp
under the hood fuse box
fuse# power point#/ location
82 2 - dash
83 1 - dash
87 5 - under seat
92 4 - back of center console
93 3 - inside center console
Old 06-10-2014, 07:55 AM
82 2 - dash
83 1 - dash
87 5 - under seat
Thank you, that's it...I searched through each fuse in the manual and didn't see it labeled that way...I could have missed it so thank you!
Old 06-10-2014, 08:25 AM
sdetweil's Avatar
I never look at the paper manual.. you can search the online one a lot easier!
ctrl-F and the string to find.
Alternator with a weak charge. Freshly Painted and powder coated motors beware scotttahoe 1999 - 2003 7.3L Power Stroke Diesel 12 12-10-2015 11:36 AM
key on power for gauges? sudsmcduff 1999 - 2003 7.3L Power Stroke Diesel 10 02-15-2015 08:00 PM
headlight power volts excavator 1994.5 - 1997 7.3L Power Stroke Diesel 4 11-08-2014 07:11 AM
No power to auxiliary power ports Dmoe512 6.7L Power Stroke Diesel 8 06-29-2014 11:23 AM
12 Volt Accy Power Point ratucker3 2009 - 2014 F150 1 04-12-2011 09:47 PM
Tags
12, 2007, 2011, console, diesel, f250, ford, inter, live, makit, point, power, radar, truck, twelve, volt, volts, weather
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
