You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Should I be putting the really expensive gas, or the really, really expensive gas in my flathead 239?
I haven't done anything about the no lead thing yet; but apart from that, should I be burning premium or regular fuel? Anybody with any suggestions about what works for them?
Thanks.
__________________
IF IT WEREN'T FOR TRUCKS THEY WOULDN'T HAVE TAILGATES!
It's not that I have too many projects......... I just don't have enough garages!
If you're running a 52 or 53 without hardened valve seats you might want to use a lead substitute, but otherwise it'll run on anything.
I just returned from a 550 mile trip and ran 85.5 octane regular unleaded with no problems including pulling hard up mountain passes with about 500 lbs in the box.
Unless your motor is built for performance - high comp heads or radical cam, you should be good with regular pump gas. IMHO
Thanks; I'll go with the 'cheap' ($0.83Can per Canadian gal) stuff.
Keith.
__________________
As I hear it, you are subbposed to use the octain in occordance with your compression, 8.5:1 compression=85 octane gas. Since the falttys came with about 6.5:1 compression the cheapest would be fine, unless you upped the compression and timming (alot) then the higher octane would be wise.
Clayton; Sounds like a good formula. Thanks......Keith.
__________________
