Fuel Pump Lobe - Ford Truck Enthusiasts Forums
Fuel Pump Lobe
Old 08-23-2010, 05:17 PM
AndysFords AndysFords is offline
AndysFords is starting off with a positive reputation.
Fuel Pump Lobe
The Fuel pump lobe on the camshaft on my 88 F350 is worn out, I took the front cover and cam gear off and the lobe comes on and off, can I buy just that lobe somewhere? I can't seem to find it anywhere, not even Ford has it.
Old 08-23-2010, 06:01 PM
oreocreaming's Avatar
oreocreaming oreocreaming is offline
oreocreaming is gaining momentum as a positive member of FTE.
you sure? iirc its 1 piece with the cam. ive got a spare cam if you need.
Old 08-23-2010, 09:52 PM
No, its two pieces and the camshaft I just bought from Advance auto parts did not come with it, I have pulled two lobes off off cam shafts I had laying here and all of them were worn out, not as bad as mine, I put my fuel pump in wrong.
Old 08-23-2010, 10:14 PM
George D.'s Avatar
George D. George D. is offline
George D. is starting off with a positive reputation.
Um I would say its time to put on an electric fule pump.
Old 08-23-2010, 10:28 PM
Rick Wallace Rick Wallace is offline
Rick Wallace is gaining momentum as a positive member of FTE.
Quote:
X-2^^^^^^^^^^^^
Old 08-23-2010, 11:00 PM
Thats what I've been running but I dont like it b/c the truck doesn't get slower when the filter stops up it just cuts off with no warning. I have tried several different fuel pumps and with a big load behind it they can't keep up.
Old 08-23-2010, 11:06 PM
Are your return lines in good shape?,The ones that go back to the tanks?
Old 08-24-2010, 01:07 AM
LCAM-01XA LCAM-01XA is offline
LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.
Quote:
What pumps have you tried? Factory is 30gph flow and like 4-7psi pressure, they got some 100-gph electric beats out there now, can't imagine one of those having issues keeping your truck supplied with fuel, seeing how even at WOT you'd be using less than half of what the factory pump moves...
Old 08-24-2010, 10:19 AM
they have 350gph if you really want. i think if it can feed a 3000hp alcohol car then it can handle a 185hp idi.
Old 08-25-2010, 10:37 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
Finding a fuel pump eccentric, International Navistar might be able to come up with one.
351M weak Fuel delivery winginit 1973 - 1979 F-100 & Larger F-Series Trucks 7 09-12-2016 11:02 PM
fuel from here to there troutski Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 10-19-2014 10:24 PM
Converting 351w roller block to mechanical fuel pump david00f150 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 12 03-11-2010 07:52 PM
fuel pump lobe? efi... roadrash63 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 08-07-2009 04:05 AM
grind off smog pump lobes in exhaust? F-150Guy Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 02-03-2005 03:28 PM
Tags
1984, 1986, 69, air, cam, diesel, eccentrics, ford, fuel, install, loab, lobe, pump, system, wear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
